the clearances were tight on the intake. on the #4 I went down .30mm and .15 on the others the exhaust was left alone. rides great although the vacuum hose on the petcock collapsed and it fell on its face. a few times. to make sure I reluctantly took some good advice and took all the shims out then tested the compression.
