changing valve seals and guides
- Granitestatekz
10 Mar 2013 09:55
On my 1100 wondering what brand of seals and guides do most like to use . motor is and will be all stock. I have never done guides , just looking for a little help. Do they just tap pound out or do I have to have them pressed out . I have have done plenty of valve shimming in the past with my old Honda CRF450 but I haven't done a head work since my XR200 days back oh 1990 ish lol. thanks for the help. Oh also I was thinking if I have the head off I was think just to get a set of stock piston rings and have the cylinder ball honed .
The topic has been locked.
- Powerstroke_fan
Re: changing valve seals and guides
10 Mar 2013 10:42
I would just go with some of the newer vition seals (i think it is). I wouldnt think brand would matter as much as long as there made out of vition. As far as valve guides go. Ive never done them myself, but iam sure you need to heat the head to get them removed. And you gotta be really careful removing them and getting new ones in. If it were mine, id be sending that to a professional shop. If the guides arent bad i probably would mess with them.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- OnkelB
10 Mar 2013 11:31
I've never done guides myself either for good reasons: I don't have the required tools (not sure about the skills either) plus if I f@ck up and break something it's on me, if the shop f@cks up and break something it's on them.
Also, you don't just tap out the old guides and tap in new ones, after changing them you need the seats recut and depending on installed valve stem height maybe the valves tipped - all in all a job best left to those who have the proper tools and skills.
77 KZ 650 B1, 82 GPz 1100 B2.
- Granitestatekz
10 Mar 2013 11:33
Ok, yeah she just smokes burns oil because the seals are bad. My buddy gave me the idea to do the guides too since I was there. He used to be a powersports tech. But I can borrow the air too that will keep the valves seal so I can do the seals without removing the head. Thanks
- turboking
10 Mar 2013 12:05
do the viton seals . :pinch: any valve guide replacement requires valve seats to be recut. :pinch: only do guides if needed :S my.02 :blink:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- LarryC
11 Mar 2013 00:34Granitestatekz wrote: On my 1100 wondering what brand of seals and guides do most like to use . motor is and will be all stock. I have never done guides , just looking for a little help. Do they just tap pound out or do I have to have them pressed out . I have have done plenty of valve shimming in the past with my old Honda CRF450 but I haven't done a head work since my XR200 days back oh 1990 ish lol. thanks for the help. Oh also I was thinking if I have the head off I was think just to get a set of stock piston rings and have the cylinder ball honed .
You can drive them out or press them out. Same goes for installation. However, beware...you will have to cut the seats afterward. Big difference between shimming lash and performing major surgery on a cylinder head.
Larry C.
- CrazyDuck
11 Mar 2013 00:56Granitestatekz wrote: Ok, yeah she just smokes burns oil because the seals are bad. My buddy gave me the idea to do the guides too since I was there. He used to be a powersports tech. But I can borrow the air too that will keep the valves seal so I can do the seals without removing the head. Thanks
I'd be curious to how that goes for you without removing the head.
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
1974 TX500
1978 TT500
2007 Aprilia SXV
- bountyhunter
11 Mar 2013 05:18
VITON is the cat's pajamas. See them on ebay sometimes.
- nads.com
11 Mar 2013 19:45 - 11 Mar 2013 19:46
I installed ape guides 5 years ago and have the head off now.
My bike has seen mostly redline and past from racing etc.
GOOD TO GO
and absolutely Viton seals the only ones to use.
GOOD TO GO
Last edit: 11 Mar 2013 19:46 by nads.com.
- peter1958
- Banned
11 Mar 2013 19:52
I replaced my guides once. Never ever again. I spent a couple days doing it. Spent hours and hours trying to get them in perfect with out a seat cutting tool. Never again. What a pita
www.kzzone.com/
- wireman
11 Mar 2013 22:20 - 11 Mar 2013 23:56Attachment dancingape.jpg not found
Theres this place in California you can get the parts from! :laugh:
Or you could just try APE.com in the vendor directory
Last edit: 11 Mar 2013 23:56 by Patton. Reason: Non- solicitation rule
- wireman
11 Mar 2013 22:50
Well at least you got to pay for the priveledge,Im still waiting to here back about ad prices. :laugh:
Id say that APE is definitely the direct connection for many parts
