Cylinder Finish
- wireman
Cylinder Finish
09 Mar 2013 23:02
You might try each on a scrap piece of material to see which affect you prefer,if you want to paint the cylinder Id say the glass beading leaves a rougher surface which is better for paint to stick too.
The following user(s) said Thank You: nivlac
- nivlac
Re: Cylinder Finish
09 Mar 2013 23:54
I'm rebuilding my kz1100. How can I bring the engine finish back? I'm thinking maybe a soda or sand blasting the fins/ exterior of the jugs. What about the head fins? What kind of paint?
1983 kz1100
1979 cb650
1979 cb650
- Roadflyer
Re: Cylinder Finish
13 Mar 2013 10:53Attachment kzmotor001.JPG not found
I lightly sand blasted mine and painted it with PJ1 satin black engine paint.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- peter1958
Re: Cylinder Finish
13 Mar 2013 11:01
PJ1 is what I use.
www.kzzone.com/
- daveo
Re: Cylinder Finish
13 Mar 2013 12:10 - 15 Mar 2013 21:28
Take a look at:
www.duplicolor.com/products/enginePaint/
DE1615 Aluminum is a near dead-on match for the original engine finish. Easy to use, durable ceramic (spray-can) finish...available at NAPA Auto Parts, or just about anywhere (click where to buy).
Cylinder head and cylinder were painted with the above.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 15 Mar 2013 21:28 by daveo. Reason: add pic
The following user(s) said Thank You: bluezbike, nivlac
