Primary chain
- spudbudy
- Kick it like you mean it
Primary chain
09 Mar 2013 14:15
Hello Gang, I can't seem to find an answer to this question. I have my 78 kz650 motor off the frame
and replacing the gaskets. Since I have the bottom pan off, I looked at the primary chain. There is slack in the chain. Does anyone know just how much is allowed or should it be tight?
Thanks in advance for any and all info.
Spudbudy
Spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles.
and climbing daily.
Re: Primary chain
09 Mar 2013 14:19
Take a look in the FSM. It describes how to measure the slack and gives the service limits. ed
Re: Primary chain
09 Mar 2013 14:37 - 09 Mar 2013 14:39
If needed, try these links for a free downloadable KZ650 service manual.
jarlef.no/Kawasaki/Series/Z/650/z650files.htm
docs.google.com/file/d/0B0LxNUBYfNL8ZTQ2...mZTdkODdh/edit?pli=1
docs.google.com/file/d/0B0LxNUBYfNL8aHFZVTRQa0M1VDg/edit?pli=1
Last edit: 09 Mar 2013 14:39 by Patton.
