WHERE TO GET HEAVY DUTY SHIFTER DETENT SPRING?????
- prostreetkz
07 Mar 2013 22:36
I can not find the heavy duty detent spring I have heard some talk about ape makes for the kz. Anyone know where to get one. Its not wanting to go into some gears but has a FULLY race prepped tranny.
- wireman
Re: WHERE TO GET HEAVY DUTY SHIFTER DETENT SPRING?????
07 Mar 2013 22:39
Its not going into gear,or not staying in gear?
Is this a new problem?
- prostreetkz
07 Mar 2013 22:42
yes new problem, not wanting to go into gear sometimes, always did great,only thing we did is put an overshift bushing in it but don't think that could cause the problem, I have been told it needs a heavy duty detent spring old one must be wore out
- wireman
07 Mar 2013 22:45
Check with ape and see what they say
- prostreetkz
07 Mar 2013 22:56
I will, was hoping someone could shed some light on a place to find the heavy duty detent spring.
- Powerstroke_fan
07 Mar 2013 23:05
Maybe check the clutch adjustment, Ive seen the clutch misadjusted and making it hard to go into gear. But also my last motor that wouldnt go into gear and or jumped out, had the bearing out on the output shaft.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- wireman
07 Mar 2013 23:06
They make/sell the overshift bushing,so they probably have dealt with the problem before and have a cure for it.
if all else fails larry might have a source for the spring
- Powerstroke_fan
07 Mar 2013 23:17
Is it wierd or just me? but its seems that i never hear poeple talking about hd springs any more. Wonder why? Maybe iam just in the wrong place at the wrong time or something.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- gpz1170
07 Mar 2013 23:17
is the problem with any gear in particular? could be on a race cut tranny, a shift fork issue or even a shift drum. is an air shifter used ?
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- Zedone
08 Mar 2013 04:36
I could only find ones for the GSXer's, they don't seem to have the Kaw ones listed. I'm sure APE will have them though.
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- LarryC
08 Mar 2013 08:06prostreetkz wrote: I can not find the heavy duty detent spring I have heard some talk about ape makes for the kz. Anyone know where to get one. Its not wanting to go into some gears but has a FULLY race prepped tranny.
I would just put a new OEM spring in it if I had doubts about the current one. If the drum is truly trying to roll by the detent, that should cure it. That's the only thing that might be happening if everything else is in order.
Might seem obvious but check the shifter isn't binding in the sprocket cover bushing and also that the trans cover isn't binding anything. I've seen issues with trans covers when a gasket isn't used.
Larry C.
- etbike3135
08 Mar 2013 09:08
Never used a "heavy duty" detent spring or even heard of it. Been racing these bikes a long time. One thing I did learn is it matters who does the work on the trans. I was always trying to find the cheapest place. Then I woulld load everything up and drive 6 hours to race and guess what, the bike didnt shift! Been send my transmissions to R&D in Clearwater Florida and never missed a shift since.
1973 Kawasaki Z1
18 years in dragbikes
