Cam timing marks dont match
  • shadow44
  • shadow44's Avatar Topic Author
05 Mar 2013 21:11
#575519
I got the pdf factory z1 manual, and a Chlimer hard copy. the timing marks dont match what I have. I have a T,1,F,4 not the 1,l,l,4 like they show in the book. I assume I should use the #1? Picture attached.
Remember, the government can not give you anything they have not first, taken from someone else.
  • pig9r
  • pig9r's Avatar
Re: Cam timing marks dont match
05 Mar 2013 21:59
#575531
The tick mark at the T is TDC for cylinders 1 and 4. Make sure you have the correct marks on the cam gears also. They can be tricky. This may help. kzrider.com/forum/2-engine/445033-79-kz1000-cam-timing-help
The following user(s) said Thank You: shadow44
06 Mar 2013 02:09 - 06 Mar 2013 13:13
#575592
In the pic posted by shadow44, the F mark is the hash on top of the letter "F" which should align with the case mark at idle rpm.
Good Fortune! :)
Last edit: 06 Mar 2013 13:13 by Patton.
  • Garn
  • Garn's Avatar
06 Mar 2013 11:33 - 06 Mar 2013 11:37
#575621
I can never understand why it is not recommended that we don't change all original Zeds with the short 5 degree advance mechanism, to the later 20 degree advance. The engine must run better! Noting that the "T" illustrated above (by Patton) are in exactly the same position for TDC of both the early and later engines.
I does drive you mad fitting a Dyna S to the older style, knowing that it has an inferior ignition advance curve.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Last edit: 06 Mar 2013 11:37 by Garn.
  • shadow44
06 Mar 2013 21:30
#575720
exactly what I needed to know. :woohoo: Saved me a set of bent valves! Thanks!!!
  • shadow44
06 Mar 2013 21:31
#575721
Good Info!
