Headbolt torque
- shadow44
Headbolt torque
05 Mar 2013 20:31
So.. stock 76 kz900. original head studs. book says 25ft lb. I have read on here 36ft lb. is better. should I go on to 36?
And should I re-torque, after the initial torque?
Remember, the government can not give you anything they have not first, taken from someone else.
- pig9r
Re: Headbolt torque
05 Mar 2013 21:00
I'll send you a PM with a link to manual. You need to torque them in the correct order also.
The following user(s) said Thank You: shadow44
- shadow44
Re: Headbolt torque
05 Mar 2013 21:04
Thanks, but no link necessary. I already have it. did the proper order, and it says 25 like my hardcopy book. Just seemed a little loose at 25. I have seen where guys say they go 36, wondered if i should go to 36.
- pig9r
Re: Headbolt torque
05 Mar 2013 21:06
Maybe 36 with APE studs. I wouldn't go any more with 35 year old bolts. Retorque after heat cycle then again at 500 miles.
- bountyhunter
Re: Headbolt torque
06 Mar 2013 01:00+1 I would not go above about 27 Ft-lbs on stock studs.pig9r wrote: Maybe 36 with APE studs. I wouldn't go any more with 35 year old bolts. Retorque after heat cycle then again at 500 miles.
- zed1015
Re: Headbolt torque
06 Mar 2013 06:28
42 lb with APE HD studs.
Stick to 25 lb with the std ones.
Run the bike then let it cool overnight and re-torque.
Re-torque again around 500 miles later.
