KZ750 P / GT750 Cafe racer build
  • daventry
  • daventry's Avatar Topic Author
05 Mar 2013 10:04 - 05 Mar 2013 10:06
#575422
I've recently picked up a 1982 KZ750 P (GT750 shaft drive), which I plan on transforming into a cafe inspired racer.
The exhaust has more holes that a block od Swiss cheese, so it needs an upgrade. I want to go with a 4 to 1, but can't find anything that will fit. Does anyone know any other models that use the same exhaust?
Last edit: 05 Mar 2013 10:06 by daventry.
  • wireman
  • wireman's Avatar
Re: KZ750 P / GT750 Cafe racer build
05 Mar 2013 11:11
#575426
What about a 650/750 header,you might need to make a rear mounting bracket but head spacing should be the same B)
The following user(s) said Thank You: daventry
  • martin_csr
  • martin_csr's Avatar
05 Mar 2013 11:49 - 05 Mar 2013 11:52
#575432
You should be able to use the exhaust system from any KZ650, KZ750-4, KZ700 or ZN700. Also, a more modern air-cooled ZR750, such as the Zephyr & ZR-7S. With a non-stock system, you'll have to fabricate a muffler bracket. Center stand clearance may be an issue.
Andy-the-Gringo's KZ650 w ZR-7S exhaust.
Last edit: 05 Mar 2013 11:52 by martin_csr.
  • daventry
06 Mar 2013 09:42
#575607
Legend. That gives me so many more options to search for.
Thanks for your help!
