head bolt technical question
  • shadow44
  • shadow44's Avatar Topic Author
04 Mar 2013 22:32
#575343
Getting ready to torque the head on my 76 KZ900. The 2 6mm bolts theat go 1 on each end of the head. 10mm heads, do they have washers under them? I would think they should have, but I have not found any in the baggie of bolts I have for that stuff. Did I misplace them or was there none? [/size] :huh:
Remember, the government can not give you anything they have not first, taken from someone else.
  • pig9r
  • pig9r's Avatar
Re: head bolt technical question
04 Mar 2013 22:39
#575344
No they do not.
The following user(s) said Thank You: shadow44
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
04 Mar 2013 22:40 - 04 Mar 2013 22:41
#575345
Last edit: 04 Mar 2013 22:41 by 4TheKZ1000.
  • shadow44
04 Mar 2013 22:49
#575347
B) Thanks guys! B)
The following user(s) said Thank You: 4TheKZ1000
