problems with my clutch.
- ILoveNasacar
03 Mar 2013 18:20
I'm having a really difficult time trying to have properly functioning clutch.
For some reason, I have really grabby plates that won't slip at all. I can't even move the bike with the clutch pulled in. The worst part is, this is happening on a set of new frictions with less than an hour of use.
I replaced the clutch a while back for the same problem that I am again having now.
so far, the steels looks fine, I probably should of replaced the springs, but didn't. I did replace the friction plates and cable, cleaned the pusher mechanism. Didn't loose the tiny little ball bearing. Even torqued everything back to spec.
It road and functioned fine for a while.
Then it started to grab again.
Maybe I have the slightest warped plate?
I just took them out and cleaned them, and replaced the oil with t6.
Maybe my springs aren't strong enough to fully grip my plates, so they're just slipping the whole time and burning the surface. I don't know. Any ideas?
1976 kz750 twin
1976 Ke175
1981 stroked w12 moon lander, autographed by Neil Armstrong, after he was revived by the church of Scientology last month.
1976 Ke175
- les holt
Re: problems with my clutch.
03 Mar 2013 18:33
I'd suspect warped steel plates. What replacement clutch did you go with? I've had barnetts get grabby and not release but it took a little time, not much, I was throwing some hard work at them.
If in fact it is warped steels, you shouldn't have to replace the fibers and used steels off e-bay can be had fairly cheap. Take the best of the bunch and make a full set.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- DoubleDub
03 Mar 2013 23:20
Springs are the first thing I would have replaced. These clutches are tough. Measure their height and compare in the FSM. The plates were probably within spec - did you measure them? Springs cost < $20. Plates are expensive.
- les holt
04 Mar 2013 07:56
Check clutch basket for scaring from the fibers, what happens sometimes is that little grooves get worn in it and they won't let the clutch fully engage or disengage and also to chatter.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- ILoveNasacar
06 Mar 2013 18:24
Thanks for the replies guys.
the landings of my basket are pretty smooth. No pitting or grooving.
I saw pictures of what warped plates look like. They'll have burnt markings on the surface where the plates wobble out of true. I didn't see any burn marks or anything. still, doesn't mean that they aren't though..
also, is a light Cross thatched pattern normal on the surface of the steels? there's a smooth side and then a semi-smooth side with light cross thatching. I figured it's designed like that for grip.
Smooth side face inward or out?
I NEED TO INVEST IN A MANUEL.
1976 kz750 twin
1976 Ke175
1976 Ke175
