kz750 ltd h2 - starter clutch repair/failures?
  • wireman
  • wireman's Avatar
Re: kz750 ltd h2 - starter clutch repair/failures?
03 Mar 2013 21:55
#575148
Nebr_Rex wrote:
wireman wrote: Why are you being charged for parts he broke during the install? :sick:
Hey SPARKIE make it to the swap meet? :whistle:
Was it in Lincoln?
Ill be hitting the swap meets this summer around lincoln with some Model A parts and extra sb chevy stuff Im tired of tripping over :laugh:
  • Nebr_Rex
  • Nebr_Rex's Avatar
03 Mar 2013 23:42
#575177
Yes,40'th annual.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • wireman
  • wireman's Avatar
03 Mar 2013 23:57
#575180
I was just talking about getting one of those high pressure parts washers that the parts sit inside and spin while the hot water blasts them,its supposed to be better than a hot tank.
Ive got a lot of old engine blocks/heads/intakes and that kind of stuff to clean up for swap meet material this summer. B)
  • Motor Head
  • Motor Head's Avatar
04 Mar 2013 00:02
#575181
donthaveakawman wrote: I don't know that it was installed correctly, there should be a mechanism that pushes the gear on the starter motor out when it is in use.
Nope, Incorrect. The KZ does Not use a Starter that has a Bendix type drive gear and a solenoid which pushes out an engagement gear. Don't get confused with this info Angel.
The KZ uses a One Way Sprag type Starter Clutch. Here is a link to a Video one how to examine and replace worn parts once it is apart.
Sorry to hear that the mechanic has treated you so un-fairly. Be Very Careful taking it back to him, get All Of your Old Parts Back. Don't pay for any extra labor, maybe just the parts the he didn't replace before. Which would be the Gear and the Roller Hub.
  • donthaveakawman
  • donthaveakawman's Avatar
04 Mar 2013 00:48 - 23 Mar 2013 01:25
#575193
should take it to a technician instead next time.
Last edit: 23 Mar 2013 01:25 by donthaveakawman. Reason: "info angel"???
