kz750 ltd h2 - starter clutch repair/failures?
  • steelhorseangel
  • steelhorseangel's Avatar Topic Author
  • ad@wildlifeartist.plus.com
03 Mar 2013 17:43
#575093
Hi riders
In my last engine post i discovered that my starter clutch had failed.
This starter spinning problem started in the cold weather.
I was unable to do this technical job myself. I've limited knowledge and
I felt best to pay a bike mechanic. Again i was ripped off. The nice mechanic
Turned out to be a creative accountant and made a big meal ticket out of
My bikes starter problem!
He brought the bike back last friday, 'some 6 weeks!' later and gave me a large invoice
For changing the starter clutch kit. He broke the new kit. Then charged me again.
He checked and shimmed the valves charged again. £450 brit pounds!
He started my bike up. Sounded new and made my day.
The next day 'from a cold night' of being back in the garage.
I half choked it, started it to hear a really loud metal on metal sound.
The bike sounded really bad. I had just paid for new insurance and road tax.
I obviously wont ride my bike in this terrible mechanical state.
I've now phoned him. He will have to re do the work again, at his cost.
Q) is there a modification that would cure forever the failing starter clutch problem?
Q) i' ve read on this forum, that a new starter kit, can fail again 3 months, what use is this.
The mechanic told me it takes him 4 hours to do a starter clutch kit replacement!
Q) why use such tiny springs for such an important job?
Q) has any kz rider modified this fragile starter clutch?
What a brilliant bike, let down by the above, any suggestions riders please?
Change all the starter clutch was advised to me today, like trying to find the Holy Grail!
Thank you for your advice kz riders!
Angel
uk
Angel
Restore, Wrench & Ride!
Brought up with Dad, brother, all riders!
Our Dad (Eric) taught us both simple mechanics
before he went to the happy hunting ground, too soon (44)
My KZ is now called Eric and he will ride and protect me!
x God Bless x
Re: kz750 ltd h2 - starter clutch repair/failures?
03 Mar 2013 19:13
#575119
What "kit" are you talking about? Have the mechanic tell you exactly which parts he replaced, and have him show you the old parts he removed. If he did not replace ALL the starter clutch parts you will still have the problem you describe.
  • donthaveakawman
  • donthaveakawman's Avatar
03 Mar 2013 20:13
#575122
did the starter and the clutch fail at the same time?
  • steelhorseangel
03 Mar 2013 20:13
#575123
hi ed!
remember me angel?
how are you!...:-)
many thanks for your reply!
the parts that i bought and he
did replace was the rollers, cups and springs
only. he advised me that he's examined
all the gears for wear. told me after he'd
fitted it, the starter sprocket, had some
wear on the 'grab face'. why fit if it had wear?
ed, are you saying that all gears
should've been replaced?
i can't find them in the uk.
do you know what i'll need for a
complete starter clutch please?
many thanks ed
angel
Angel
x God Bless x
  • wireman
  • wireman's Avatar
03 Mar 2013 20:16
#575126
Why are you being charged for parts he broke during the install? :sick:
  • steelhorseangel
03 Mar 2013 20:17
#575127
hi donthav
thanks for your message!
the clutch worked perfectly.
on starting the bike, it wouldn't start
properly. it just spun. the starter clutch
is a common fault on the kz's, also
other makes!
regards and thanks
angel
Angel
x God Bless x
  • donthaveakawman
03 Mar 2013 20:19
#575128
I don't know that it was installed correctly, there should be a mechanism that pushes the gear on the starter motor out when it is in use.
  • steelhorseangel
03 Mar 2013 20:22
#575131
hi wireman!
many thanks for your reply.
the mechanic is a con man.
he even charged me for my own
parts supplied? i've never used him
before. i won't again!
he's coming to collect my bike and
sort it out properly. the bounder!
are you a sparkie, electrician, mr wireman?
i've just bought a honda goldwing, for touring.
fancy rewiring it for me?
thanks again!
angel
Angel
x God Bless x
  • steelhorseangel
03 Mar 2013 20:25
#575132
the starter clutch was broken.
the little springs were damaged by
wear & tear!
regards
angel
Angel
x God Bless x
  • donthaveakawman
03 Mar 2013 20:25
#575133
mine makes that metal sound on occasion.
  • Nebr_Rex
  • Nebr_Rex's Avatar
03 Mar 2013 20:46
#575138
wireman wrote: Why are you being charged for parts he broke during the install? :sick:
Hey SPARKIE make it to the swap meet? :whistle:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
03 Mar 2013 20:56 - 03 Mar 2013 20:57
#575141
steelhorseangel wrote:
...he advised me that he's examined all the gears for wear. told me after he'd
fitted it, the starter sprocket, had some wear on the 'grab face'. why fit if it had wear?
angel
Right! Why fit it if it had wear? He should have replaced it. They are not at all difficult to acquire; any Kawasaki dealer can simply order one because they are still an "Active" part.
Last edit: 03 Mar 2013 20:57 by 650ed.
The following user(s) said Thank You: steelhorseangel
