custom ground cams
- donthaveakawman
custom ground cams
02 Mar 2013 19:08
curious about regrinding the cams at a local cam shop. if I adjust the clearances and get some taken off the back of the lobe what would I gain? lift, lobe, timing is probably not going to change, horsepower...
Re: custom ground cams
02 Mar 2013 20:22donthaveakawman wrote: curious about regrinding the cams at a local cam shop. if I adjust the clearances and get some taken off the back of the lobe what would I gain? lift, lobe, timing is probably not going to change, horsepower...
You would gain nothing but more problems to go with your tractor muffler :pinch:
The following user(s) said Thank You: wireman, lushbaugh
- Lorcan
- Speed Loony
02 Mar 2013 21:13
Learn how to walk before you try to run.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- donthaveakawman
02 Mar 2013 21:27
I have emailed a cam company and let them know I will be posting this. I have done business there before I want to see what gains I would get.
being that they are adjustable lifters I would think that it is do-able but not sure what I would gain.
- DoubleDub
02 Mar 2013 22:03donthaveakawman wrote: I have emailed a cam company and let them know I will be posting this. I have done business there before I want to see what gains I would get.
I want to see there response! You're a funny guy, Don the Caveman. :laugh:
- donthaveakawman
04 Mar 2013 19:52 - 04 Mar 2013 19:53
it was actually a facebook conversation. I told them advertisement is not their strong point. 20-20
Last edit: 04 Mar 2013 19:53 by donthaveakawman.
- donthaveakawman
18 Mar 2013 03:47
I must admit this thing ran way faster before taking the valve adjustment down to spec, even with 60psi on the#2 cylinder!!!!
