head gasket
- brianrae33
head gasket
02 Mar 2013 02:56
just put a new head gasket on..might have to take the head back off,,bikes never been started,,should i get a new head gasket????
1982 kz1000ltd
- wireman
Re: head gasket
02 Mar 2013 03:04
Id say it depends on what kind of luck you have! :woohoo:
Attachment dice.png not found
- donthaveakawman
Re: head gasket
02 Mar 2013 03:46 - 02 Mar 2013 03:47
I don't know exactly what you are saying, persay but if you have non used the head gasket I would guess with the torque specs that are so low due to the aluminum engine that a non used head gasket should be ok.
Last edit: 02 Mar 2013 03:47 by donthaveakawman. Reason: forgot to hit the spacebar and it turned out saying persaybut
- roy-b-boy-b
Re: head gasket
02 Mar 2013 10:43
I reuse head gaskets all the time. I use copper coat on both sides and let it cure over night. Roy
The following user(s) said Thank You: Patton
- wireman
Re: head gasket
02 Mar 2013 12:52
Ive never had much luck gambling. :woohoo:
- turboking
Re: head gasket
02 Mar 2013 13:08
copper ,you can anneal and coat for reuse
. :huh: oem fiber head gasket, you may get away with reusing after spraying with copper coat sealant.
:pinch: cometic graphite will probably self destruct upon removal......IMO, the graphite is the best to use for the street , no leaks.
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- bountyhunter
Re: head gasket
03 Mar 2013 18:02I did it once on a very good quality head gasket that have a few hundred miles on it. I also used the copper spray stuff. Worked very well.roy-b-boy-b wrote: I reuse head gaskets all the time. I use copper coat on both sides and let it cure over night. Roy
