Engine Break in after Rebuild
- bountyhunter
Re: Engine Break in after Rebuild
02 Mar 2013 03:43I lost mine in the first divorce.....steell wrote: Break it in like the professional engine builders do, put it on an inertia (Dynojet) dyno
- donthaveakawman
02 Mar 2013 03:51
a person could use the center stand high gear and calculate the rpm by the gear ratio for 500 miles but I don't think it would be helpful if you want to do it correctly you will have to ride it- get it kz rider
02 Mar 2013 13:17
Lots of differing opinions, but the correct way, while not actually described in the Owners Manual, is demonstrated below.
02 Mar 2013 13:32
:woohoo: :lol: :lol: :lol:
- steell
02 Mar 2013 14:46Patton wrote: Yeah steell don't u no nuthin? :lol:
Heck no! If I did I'd be dangerous!!
- Powerstroke_fan
02 Mar 2013 15:12donthaveakawman wrote: a person could use the center stand high gear and calculate the rpm by the gear ratio for 500 miles but I don't think it would be helpful if you want to do it correctly you will have to ride it- get it kz rider
Ya donthaveakawman, i would put it on the center stand and run it like that :ohmy: Let me know how well that air cooled motor likes it...
1977 KZ 1000 work in progress
- gd4now
- Denco where did you go?
02 Mar 2013 18:56
This topic - engine break in process - is almost as polarizing as the stock air box vrs pods issue.
Do not know that I believe all here but I did find this an interesting read. www.mototuneusa.com/break_in_secrets.htm According to him, it is dependent upon what sort of honing is done - than more modern engines have a very fine hatch pattern that the older engines did not.
Anyway wanted to pass this on for others to read and make of it what they wish.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: lushbaugh, monroeraustin
- monroeraustin
03 Mar 2013 02:29
Ok thanks to all for the feed back but now I'm confused as hell! I guess I'll worry about it when the time comes.
- lushbaugh
- everybodys a pro......
03 Mar 2013 02:34
i run brad penn zinc oil and run the hell outta mine then change oil. thats just me, i was taught that runnin them easy creates un even wear. but the post on break in makes more sense with same results. but every cylinder ive honed has tight crosshatching anyway as thats just what i learned early on. its just for ring seating so finer more consistant hatch makes more sense on a precision part.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
The following user(s) said Thank You: monroeraustin
- donthaveakawman
03 Mar 2013 02:54
I would be careful even after the break in, but this is about you not me, sorry.
- monroeraustin
03 Mar 2013 15:37donthaveakawman wrote: I would be careful even after the break in, but this is about you not me, sorry.
I surely would like to know what you mean by being careful.. Baby the damn thing for how long. its gonna be used for commuting back and forth to work.. 17 miles each way..
- Powerstroke_fan
03 Mar 2013 15:47
I wouldnt pay to much attention to donthaveakawman. But while breaking it in i would normally break it in how it will be drove. If it was me i would start it for the first time and let it run for a couple min then baby it for the first 20 miles. Then slowly start workin on it.
