CHERRY RED EXHAUST?????
- NakedFun
Re: CHERRY RED EXHAUST?????
26 Feb 2013 19:55 - 26 Feb 2013 19:57
Well the mixture screws on the BS34's are fed off the pilot circuit for fuel. They mix with air from the Air Pilot Jet on the other side of the carb. I would say you have a blocked pilot since the mixture screws are not doing anything, thus the supply of fuel to them may be compromised. When they cleaned the carbs, did they pop out the plug at the bottom of the pilot passage near the main jet? Perhaps they didn't put it back in? Maybe that is what was messing with your float movement which caused your initial issue? It may be time to pull the bowls....
Edit: if your carbs have the main passage feed for pilots and not the direct feed like later model carbs. Don't know what you have on your bike.
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
Last edit: 26 Feb 2013 19:57 by NakedFun.
- Steve1986
26 Feb 2013 21:44
they are the mikuni cv carbs. i know the measurements for the pods were 58mm if that helps and the adjustment screw is on the top front
1982 kz1000J
Miles-6700
Miles-6700
- NakedFun
26 Feb 2013 22:47
I know they are CV Mikunis (BS series) but earlier carbs had a pilot passage that fed off a cross over from the main jet passage. The pilot had a plug in it at the very bottom to seal up after machining. They then changed to removing the plug and plugging the cross over passage, causing the pilot to pull right from the bowl.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- Steve1986
27 Feb 2013 07:27
are you talking about the plug inside the bowl of the carb it about the size of a pencil eraser if so they are in there
1982 kz1000J
Miles-6700
Miles-6700
- NakedFun
27 Feb 2013 08:20
Yep those were the ones I was talking about.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- Steve1986
05 Mar 2013 18:39
little update on my problem- i checked the carb boot or intake boots which ever you prefer and they do leak 2 of them very badly. so im hopeful after replacing them and re-tuning/sync my bike it will be back to normal any one have any suggestions on were to get them without being too expensive ?
1982 kz1000J
Miles-6700
Miles-6700
05 Mar 2013 18:49
www.partsnmore.com/parts/kawasaki/kz1000j/?filters
[category]=carb&filters[fitting]=custom
or z1enterprise
or z1enterprise
The following user(s) said Thank You: Steve1986
05 Mar 2013 20:48
The ones for your bike are still available from Kawasaki so any dealer can get them. Ronayers.com lists them at around $15 each. Replace all 4 while you have the carbs off. One other suggestion - soak the carb holders screws that attach them to the cylinder head with Kroil for a couple days before trying to remove them and they will come out without much trouble. And assuming yours still have the crosshead screws, be sure to use a JIS type screwdriver tip (ask if you don't know what I mean) because a Phillips tip will cam out and damage the screw heads. Ed
- Steve1986
05 Mar 2013 21:59
I planned on buying all 4 i just was just hunting the best deal thanks for the soaking tip 650ed will do. and i actually read about those screws on this forum which i didn't know about before lots of hours logged here
1982 kz1000J
Miles-6700
Miles-6700
