CHERRY RED EXHAUST?????
- Steve1986
25 Feb 2013 21:30
So my first ride of the year and on this bike was a big fail. I finally got a nice day to get my bike out I started it no problem went to get my things together to leave (about 10 minuets) on when i returned to the bike it was puking fuel and the right side exhaust was super hot Turned it blue. bike was popping idling ruff i shut the bike down right away i could see the fuel leaking from the second carb from the right if your sitting on it. i gave the bowl a light tape and it stopped so im assuming this is a stuck float ? i then restarted the bike it fired right back up no fuel leak but the pipe that was super hot is know heating up alot slower than the other pipe it did warm up but slowly i went for a short ride and its got no power some backfire under load im talking 60mph is all it would give and it was slow getting there. But it idles like it should and its steady and starts right up. here's the best part
i just got this bike back from a carb cleaning and sync with new mixture screws and o-rings. total bill $350.00 My question is what would cause a extreme in heat like that ??? why would it idle but run like junk under load? i am going back to the mechanic tomorrow :ohmy: im thinking its something the mechanic or do i have a new problem ?
1982 kz1000J
Miles-6700
Miles-6700
Re: CHERRY RED EXHAUST?????
26 Feb 2013 01:36
Timing advancer might be stuck.
Could try lubing the pivot points.
- trianglelaguna
26 Feb 2013 01:42
air cooled bikes....need air moving by the engine
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
The following user(s) said Thank You: Steve1986
- Steve1986
26 Feb 2013 09:01
i will look into the timing advancer WILL that make the extremes in heatand power loss. i know it needs air moving to stay cool but i always let my bikes warm up before leaving.(10 min or so) heck my 550ltd u could leave run forever with no issue and it wasnt super hot out yesterday 47 degrees. it worries me to think what it will do on a summer day when it 80 or 90 out. thanks for the tips though
1982 kz1000J
Miles-6700
Miles-6700
- peter1958
- Banned
26 Feb 2013 11:41
where in pa
www.kzzone.com/
- Steve1986
26 Feb 2013 14:44
im in trevorton pa. i just talked to the mechanic that did my carb work (not happy) he tell me it getting way to much fuel how is this possible with stock jets and exhaust. with pod filter? mechanics also tells me he has my mixture screws set at half a turn open. im going crazy with this dam thing
1982 kz1000J
Miles-6700
Miles-6700
- kzz1king
26 Feb 2013 15:16
If the bike was flooding the cylinder I would try a new plug or better yet swap the plugs and see if the problem moves.
Wayne
Wayne
Home built KZ1000 turbo setup
- NakedFun
26 Feb 2013 15:23 - 26 Feb 2013 15:51
Puking fuel and red hit exhaust could your floats be stuck or set too high? Just a thought. If your timing event is occurring too late as stated with a sticking points plate, you will have the glowing exhaust and poor running at lower speeds. Honestly, I would expect a lean condition to cause a glowing exhaust more than a rich condition. Could you have had junk that cause the float sticking to cause a pilot plugging?
FWIW,
Cory
FWIW,
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
Last edit: 26 Feb 2013 15:51 by NakedFun. Reason: Added one more thought...
- Steve1986
26 Feb 2013 16:28
OK i just pulled the plugs the side that is having the heat issue (right pair of cylinder if your on it) plugs were black the side that appeared fine were white which suggest lean on the left and rich on the right pair. i cleaned and re-gaped all 4 plugs put them in fired it up did the same thing im also having back fire out the air filters on the lean side, this make me think the carbs are not set properly and if thats the case how well were they really cleaned? I am going to check the advancer when i get the chance but i dont think this is it due to the fact it ran pretty decent before i took it to the shop NAKEDFUN-- it was a stuck float a little tapping on the bowls made it stop im lost and my local shop doesnt seem to wanna due anything about it
1982 kz1000J
Miles-6700
Miles-6700
- NakedFun
26 Feb 2013 17:25
Steve,
If I were closer, I would help you out. From what you are saying, this seems to be a fueling issue and not ignition/advancer. Since you have two different plugs telling you the exact opposite, there is obviously something going on with the carbs. How are your intake boots/manifolds? Are they showing signs of cracking/ They could be craeting a vaccum leak and one cylinder to run lean, due to a weak carb signal. If you had marginal boots, when you reinstalled the carbs, you created some cracks. With the engine running, spray some carb cleaner using the straw, around the carb boots, manifold to cylinder head, etc.. and see if temporarily the engine smooths out. If it does, then that is your culprit. If it doesn't, then it is time to pull the bowls and using the carb cleaner and straw, shoot some cleaner into the pilot and main jets. You may have had debris that didn't get out, hang around and plug the pilot.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- Steve1986
26 Feb 2013 17:56
i was thinking carb issue as well i will do the spray test to the carb boots they looked ok when it was apart but i have been wrong before if they were leaking wouldn't that have shown when it was hooked up? also what would it mean if the mixture screws do little in affecting the engine when turned (they are new with new o-rings)that is the reason i was given for them being set at 1/2 turn out
1982 kz1000J
Miles-6700
Miles-6700
- Hollywoodmx
26 Feb 2013 18:26
I second on the boots. Been there before. Also the float could be set wrong on the two lean carbs.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
