cam timing-compression or exhaust stoke
  • donthaveakawman
  • donthaveakawman's Avatar
Re: cam timing-compression or exhaust stoke
26 Feb 2013 20:13
#574292
I am currently in the making of adjusting my valves via waiting for postal, did you get a chance to check the clearances?
  • brodavid
  • brodavid's Avatar Topic Author
26 Feb 2013 22:57
#574318
Yeah, All within >005-.015mm specs . Still don't know why it's running so weak. Ran it around the block just too much vibration and not enough guts.
1981 kz 1000 ltd k1
26 Feb 2013 23:04
#574319
Might be running on just two cylinders. Would perform spray-water test on headers.
Ignition timing might be stuck in idle position.
Would assure weighted arms are freely moving on pivots.
Good Fortune! :)
The following user(s) said Thank You: brodavid
  • donthaveakawman
26 Feb 2013 23:48
#574328
not sure if you have cvc carbs but I have had stuck slides in the past.
  • donthaveakawman
26 Feb 2013 23:55
#574330
the intake cam mark and the exhaust cam mark should be 44 chain pins apart and on opposite sides from each other. correct me if I am wrong patton I have a small 4.
  • brodavid
27 Feb 2013 22:16
#574482
Want to thank everyone for their input on my top end rebuild project. Finally got the problem fixed. The primary coil wire on #2 coil open connection. Thanks for the heads up Patton on the spray water test on the headers. Best choice I've made by replacing seals ,gaskets,re-shim and remove old carbon from top end. Runs like a new one!
1981 kz 1000 ltd k1
