clutch cover oil window
  • shadow44
  • shadow44's Avatar Topic Author
24 Feb 2013 19:00
#573923
Anyone know how I can get the oil window out of the clutch cover so I can powder coat it? :blush:
Remember, the government can not give you anything they have not first, taken from someone else.
  • The Milkman
  • The Milkman's Avatar
Re: clutch cover oil window
24 Feb 2013 19:20
#573926
Don't know what bike you have, but on my 650 it just tapped out and a new one taps back in. Get a new one, it's sealed in rubber and put it in dry. I used a wood dowel and hammer to change mine.
Les
The following user(s) said Thank You: GPz550D1, shadow44, wireman
  • Turbogus
  • Turbogus's Avatar
27 Feb 2013 20:25
#574466
Years ago on my Z1R I had the same symptom, but cured it with a tip from a magazine. I can't recall just what the procedure was but you may not need to replace the window.
Sure you can trust the Government.....
ask any indian
