What is the best replacement clutch pack?
- badrhino
24 Feb 2013 16:32
On the few times I've had my bike out I can tell the clutch is slipping a bit. So I will be needing new friction plates. I seen this one at Z1E. Is this one of the best ones for the J model for the price?
www.z1enterprises.com/ItemDetails.aspx?i...Z1100&item=APCK1100K
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- 4TheKZ1000
Re: What is the best replacement clutch pack?
24 Feb 2013 17:00
Over and over the people in the know say ....stock Kawasaki OEM.....
- wireman
24 Feb 2013 17:00
www.z1enterprises.com/ItemDetails.aspx?i...asaki&item=KL17-7184
I prefer the stock discs myself.
you might see if they have a set of replacement discs,might be cheaper than individual prices
- zukdave
24 Feb 2013 19:46 - 24 Feb 2013 19:50
From all the reading I've done about it I think
stock Kaw. if you can find them.
Next best I think would be these APE's clutch's.
kzzone.com/clutches.html
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 24 Feb 2013 19:50 by zukdave.
- APE Jay
24 Feb 2013 20:11
The original oem disc haven't been available for nearly 15 years. The stuff from dealers is not the same. No idwa where the stuff they sell now comes from.
In any case our clutch he shows from Z1 has always been the best you could use.
- wireman
24 Feb 2013 20:42
And once again some of the actual manufacturers are
www.google.com/aclk?sa=l&ai=CHQK5yKQqUZr...s/%3Fsource%3Dgoogle
- wireman
24 Feb 2013 20:45
:laugh:
- badrhino
24 Feb 2013 22:53
I'll prob. go with the APE ones I had a link to. They are just as cheap as the others I have seen. Thanks!
Franken Z!
Franken Z!
