77 KZ 650 B engine rebuild
  • 3cav84a
  • 3cav84a's Avatar Topic Author
23 Feb 2013 20:53 - 23 Feb 2013 21:01
#573757
Attachment KZ650crankcase.png not found
G'day, I am starting to assemble my 1977 KZ650 B after soda blasting the engine and renewing gaskets and seals. I downloaded several pages from the Kawasaki website and I can't figure out where these O rings go. They are number 4 in the parts diagram, part number 92055-099 it says they are 8.8mm. I took heaps of photos as I was stripping the motor and I can't remember seeing them. It looks like they might go in the stud holes next to the cam chain well but I can't be sure.
Also when the cam chain idler is placed in the well are there rubber blocks that sit on the axle before the base gasket is placed into position, regards Neil
1977 KZ 1000 A1
Last edit: 23 Feb 2013 21:01 by 3cav84a. Reason: add picture
  • DFIGPZ
  • DFIGPZ's Avatar
Re: 77 KZ 650 B engine rebuild
23 Feb 2013 22:28
#573784
the orings are just to seal oil from coming up through studs as the holes are bored straight through cases i have seen them both ways w/o orings and with orings and yes they go around base of cyl studs myself i always used them, as for the rubber damper blocks they go directly on top the axle then base gasket goes on top.
1984 750 Turbo
The following user(s) said Thank You: 3cav84a
  • 3cav84a
24 Feb 2013 00:10
#573800
Thanks for the info, the gasket kit I am using didn't have those O rings included so I might just put some high temp silicone round the base of the studs, regards Neil
1977 KZ 1000 A1
