Engine Oil Cooler Mount
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
21 Feb 2013 00:16 - 08 May 2013 00:11
#573394
I’m
Last edit: 08 May 2013 00:11 by 4TheKZ1000.
  • MFolks
  • MFolks's Avatar
Re: Engine Oil Cooler Mount
21 Feb 2013 00:24
#573396
What kind of supply and return lines being used? If SS braided, the SS will act like a slow speed file, and wear through paint,electrical wiring,brake lines, and other oil lines.
  • 4TheKZ1000
21 Feb 2013 00:33
#573399
AN-6 Braided Stainless Steel Hose.
Your right on the braided line, if not well thought out....it will wear on anything it touches.
Im on it....no problems for me.....but thanks for heads up.
Will post pics when weather improves and can get bike in sunshine.....garage is too dark..... ;)
  • wireman
  • wireman's Avatar
21 Feb 2013 00:38
#573400
[attachment:1]C:\fakepath\popcorn_2011-05-24.jpg[/attachment]
The following user(s) said Thank You: 4TheKZ1000
  • 4TheKZ1000
21 Feb 2013 00:48 - 21 Feb 2013 00:51
#573402
Im going to have mine pretty much hidden.....only a few inches will show.
I will have 3 rub points that matter....will be using 3-mill black shrink tubing at these points to correct problem and protect from rubbing. Normal shrink tube is 1-mill thickness.
Last edit: 21 Feb 2013 00:51 by 4TheKZ1000.
  • wireman
  • wireman's Avatar
21 Feb 2013 01:19
#573409
Attachment popcorn_2013-02-20.gif not found
  • ramtough_63
  • ramtough_63's Avatar
21 Feb 2013 13:17
#573448
I really want to see 'er when your finished I have an oils cooler on the 77 but not a fan of aftermarket coolers. looks that is most of my riding is in 80 plus degree weather so I know in town I'd benefit greatly
obtw nice cooler
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • pete greek1
  • pete greek1's Avatar
21 Feb 2013 13:32
#573450
I dont know if this helps, but I talked to the people at Valley Hydralic Services in South Elgin Ill. & they said they have braided stainless steel hose with a plastic coating, it can be clear, or many other colors, maybe maroon for your application, they say its heat resistent up to 250 degrees, I dont know how hot the parts are going to be, that your worried about the hose touching or rubbing against ...Pete
  • 4TheKZ1000
21 Feb 2013 14:46 - 21 Feb 2013 14:56
#573460
pete greek1 wrote: I dont know if this helps, but I talked to the people at Valley Hydralic Services in South Elgin Ill. & they said they have braided stainless steel hose with a plastic coating, it can be clear, or many other colors, maybe maroon for your application, they say its heat resistent up to 250 degrees, I dont know how hot the parts are going to be, that your worried about the hose touching or rubbing against ...Pete
On stainless steel braided hose.....It might bump the very top 2 inch of front valve cover. Its going under tank and down between carbs and engine. I will put some on where it can contact the carb boot. Im talking in all 1 - two inch section and 2 - 3 inch sections in all. Its really not going to be a prob.
Last edit: 21 Feb 2013 14:56 by 4TheKZ1000.
  • pete greek1
21 Feb 2013 14:51
#573462
I cant wait to see pics, when your done, I want to do the same thing to mine :woohoo: :woohoo:
  • 4TheKZ1000
21 Feb 2013 15:07
#573464
One thing my bike dosent have is the the center down tube flat steel brace.
I took mine out when it was raked and slugged 7 inches of downtube for strenght....then braced frame going back. This is the brace that lockhart coolers bolt to.
So I can run my cooler lines stright back off the cooler up between the downtubes and under tank....I dont have the brace in the way or have to go around it. You dont see any of the hose off the cooler in front. I will wire tie the braided line to under tank frame rails that will act as a heat sink also.
My garage is to dark to get pics....I will post in great detail when I can roll outside on a sunny day.
  • Zedone
  • Zedone's Avatar
22 Feb 2013 21:53
#573624
Looks really good 4thek. They also have clear shrink tubing for brake lines @ Motion Pro... if I remember right. But I have not seen it for the larger SS lines at their website.
Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
