Unauthorized Excursion - dropped parts into case
  • Rickman
  • Rickman's Avatar Topic Author
19 Feb 2013 12:55
#573168
Warning! Intruder detected! :blink: Attention, J-model gurus...
So as I was placing the cylinder block back on the base, the rear cam chain guide got caught up somewhere. When I tried to push it into the proper position it rose up out of its slot and a small metal block went AWOL, down the oil canyon to crankshaft land! I think it was the 'cam chain guide holder'. I almost had it with the pliers, but it slipped. It must have gone back into the gears because I cannot see it at all now, nor reach it with my magnets.
:angry:
So guys, Ya think I'll find it if I drop the pan, or is it gonna be time to put it on the bench and split the cases?
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
Re: Unauthorized Excursion - dropped parts into case
19 Feb 2013 13:02
#573170
Forgive me if this sounds dumb (just consider the source), but if the engine is out of the frame is it possible to flip it upside down and shake the piece out? Ed
  • trianglelaguna
  • trianglelaguna's Avatar
19 Feb 2013 13:18
#573174
if it cant be upside down and drop out then pulling the pan and gently rotating the crank may give it up?
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • turboking
  • turboking's Avatar
19 Feb 2013 13:34
#573176
errrrrrr I did something like that once...... :unsure: it wedged in the main cap cavity where the cam chain is. I had to drop the pan and R&R the main cap to retreive it.... :huh:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
The following user(s) said Thank You: Rickman
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
19 Feb 2013 14:00 - 19 Feb 2013 14:01
#573178
Before you do anything, try this. You have nothing to lose. Try leaning the engine or bike from side to side . Hopefully the part will slide back and forth and the magnet on the drain plug will grab it. This may work or not and only if the part is in the pan of course. May work better without oil. So if you have oil in the engine. You will automatically find out if it worked when you pull the drain plug. If it didn't work take another shot at it without the oil in there. My front cam chain guide came out with the drain plug when doing an oil change. That is how I found out it was broken, LOL. If that doesn't work, and the other suggestions didn't work, then drop the pan.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 19 Feb 2013 14:01 by KZJOE900.
  • Rickman
19 Feb 2013 14:21
#573179
Turboking, you're really scaring me. :ohmy:
KZJoe900 and all, sounds like there is probably room for it to get around, and removing the oil pan should allow enough access to find this bugger.
I think it is too large to go through the drain plug, but maybe when I pull the filter cover tonight I'll be lucky.
thanks
Rick
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
19 Feb 2013 14:33 - 19 Feb 2013 14:33
#573182
Filter is in its own housing and the oil is pumped into it via passages. In other other words, the oil filter resides in a sort of cylinder separated from the oil pan. In either case, you will be pulling the oil drain anyhow. So a little shake-n-bake beforehand won't hurt anyhting, :P .
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 19 Feb 2013 14:33 by KZJOE900.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
19 Feb 2013 19:13
#573221
If you pull the pan out and its not there i would try to shine a light up there and see if it can be seen. If not i have used compressed air to move it enough to get it with a magnet or let it fall out. I just always hated turning it over anything could happen. But the air could blow it to bad places also.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
