clutch is a bit hard how can i ease it up a bit
- jbalet666
so I've been putting around on my 82 650 csr
and Ive been noticing my clutch is hard to engage
At first I thought it was because I wasn't used to it
But now its becoming an annoyance
Its mostly a problem in first gear
Having trouble slipping in the clutch and stalling the bike
Feels like I have to pretty much dump the clutch into first which makes for a quick and not so gradual acceleration
I know you can't have too soft of a clutch but I just need to ease it up a bit
Can this be adjusted via the clutch adjustment or cable etc or something more serious ie the clutch pack?
81 650csr
AoA
old soul young blood
- Roadflyer
- Thank you received: 13
jbalet666 wrote: Hey everyone your favorite noob here
Try a new clutch cable. Old bike come with old cables that just don't slide well.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- jbalet666
Will do
Thanks for the help
81 650csr
AoA
- MFolks
- Thank you received: 540
A good cleaning and re-lubing will make clutch use more enjoyable.
- jbalet666
MFolks wrote: I'm not familiar with the Kz650 clutch mechanism, but when the sprocket cover is off to install the new clutch cable,look for chain lube build up on the clutch push rod. A rag with paint thinner will remove it easily, also look for signs of wear on the throw out, or actuating mechanism too.
Thanks
Any recommendations as to what to use for re-lubrication
81 650csr
AoA
- MFolks
- jbalet666
MFolks wrote: Possibly a high temperature grease containing "Moly", as the area does get hot, and lower temp greases may flow away from the moving parts. A can of wheel bearing grease should last a long time.
Thanks for the help
81 650csr
AoA
- Thank you received: 1656
The owner's manual & factory service manual have the correct procedure. The Clymer manual has the applicable procedure in the supplement.
If you replace the cable, be prepared for a big ole' mess behind the clutch/sprocket cover. You probably ought to go ahead & clean/lubricate the clutch release mechanism. Install a new cotter pin - it helps to keep the cable end in place. Be sure to Lubricate the clutch lever pivot point & cable ends.
- jbalet666
martin_csr wrote: Have you tried a basic clutch adjustment? Ask WABBMW about that. hee.
Well last night I pulled the adjustment cover plate off and adjusted it
unfortunately it was raining so I'll find out today if I improved at all
I am going to check the cable for burs and rust and what not as well today
And try to "service" today
Is there anything else I should be looking for while I'm at it today?
81 650csr
AoA
- jbalet666
martin_csr wrote: When doing the adjustment, turn the clutch release adjusting screw in the correct direction - ie, counterclockwise 1st, then clockwise 1/4 turn.
That exactly what I did
Thanks for the advice
81 650csr
AoA
