Another question on base gaskets
- aek
19 Feb 2013 01:58
I am reassembling a 1980 750-4 motor. My service manual says to install the cylinder base gasket dry except for the cam chain tunnel area. The gasket supplied differs from the original being a crushable metal gasket and I'm thinking of avoiding the gasket cement altogether. Anyone with a ya or nay on this would be welcome!!
art
Thanks for the great resource this forum offers!!
art
1980 750-4 LTD original owner
- wireman
Re: Another question on base gaskets
19 Feb 2013 02:33
Both sides of gasket,let it tack up and install
Attachment coppercoat.png not found
- aek
19 Feb 2013 02:49
Thank you wireman - That stuff has been around a long time! Even longer than me I bet. maybe the old stuff is the good stuff!
art
art
- wireman
19 Feb 2013 02:54
My backhoe mechanic got me hooked on the stuff years ago,its da bomb in my book aanyway!
- aek
19 Feb 2013 03:53
And I'm torn the other way! My shop mechanic was fanatical about torquing everything and taking as long as it took (hell it was my time!) to get clean flat gasket surfaces and then installing gaskets dry. Didn't have leaks and it sure is a lot easier to go back. He's long gone but still has a lot of influence I guess.
art
this was on excavators and loaders etc.
art
- wireman
19 Feb 2013 04:31 - 19 Feb 2013 04:32
I just don't like taking chances as far in as that gasket is to fix,as far as clean freaks go with motor building Im about the most anal retentive prick in the world! :woohoo:
Im one of those guys who takes a hotsy to trucks/tractors once a week whether they needed it or not top/bottem.
Even my beater bikes can be eaten off of any part of! :laugh:
Attachment z1-0668a15e9d2f4eac12f2d0e9ca39dbb9_2013-02-19.jpg not found
Last edit: 19 Feb 2013 04:32 by wireman.
- aek
19 Feb 2013 04:52
I know! That's what makes the decision more interesting! I'll let you know if I go wrong on this. Thanks for your input.
art
art
- monroeraustin
28 Feb 2013 19:01 - 28 Feb 2013 19:06
I am glad I ran across this post.. I also installed a crushable base gasket and also have installed it dry except for around the rear cam chain and 4 bolts.. I am reading this post and it was mentioned to use cooper spray gasket on both sides... Does this mean I need to take the engine apart and apply the cooper base gasket sealer.. or will it leak if I don’t use it?
You would think it would be made clear in the manual as the manual does not say to use copper gasket. I don’t want to get this engine back together and then it starts leaking..
Attachment example.JPG not found
Last edit: 28 Feb 2013 19:06 by monroeraustin.
- wireman
28 Feb 2013 19:06
Id say its a matter of personal preference,I just go with what works for me anyway
The following user(s) said Thank You: monroeraustin
- Powerstroke_fan
28 Feb 2013 19:32wireman wrote: I just don't like taking chances as far in as that gasket is to fix,as far as clean freaks go with motor building Im about the most anal retentive prick in the world! :woohoo:
Dont think i would wanna eat anything off that bike. By the way the picture looks,any food would be rotted. :woohoo: :laugh:
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
