Oil Pump spec.
  • THR
  • THR's Avatar Topic Author
Oil Pump spec.
17 Feb 2013 22:26
#572919
I'm looking for spec. on KZ1000 oil pumps, mainly the volume and if there are pumps that are used for drag racing.
Hoping to find something with a little higher volume for long runs at full throttle.
Thanks.
79 KZ 1000 MKII
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
Re: Oil Pump spec.
20 Feb 2013 18:58
#573351
since no one has answered this there is a spec sheet in your factory service manual, i dont have mine anywhere near close but maybe someone can check theres
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • zed1015
  • zed1015's Avatar
Re: Oil Pump spec.
21 Feb 2013 06:14
#573433
All the z9/1000/1100 pumps flow the same .
There's nothing you can do with them except check for scoring and fit the thinnest paper gasket to tighten the side clearance up if needed.
You can get a Billet 40% extra flow pump from Turbomaxx www.turbomaxx.de/oelpumpenkit.html but you need the deep sump for it too.
They are nice bits of kit as i have one for my 1428 project but a good std pump will be up to the job of whatever you can throw at it.
  • turboking
  • turboking's Avatar
Re: Oil Pump spec.
21 Feb 2013 10:36
#573439
B) cool set up and site :blink: Sure I want one ,but at $1650.00 usd plus ship ..it's on my wish list
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
