Ok here is my problem with my clutch, I went to start it and it was really stiff so I squeezed harder and something let loose but I had no clutch. Opened it up to check actuator and everything was fine pulled the push rod, don’t know why looked fine put it all back together and nothing. I read some forums and said there was a bearing that needed to go between pushrod and clutch pack. I got a bearing put it in put it back together and clutch was nice put it in first and no go almost like clutch was not releasing. Took bearing out and still no clutch, so I adjusted the cable adjusters all the way out and was able to get tension but clicked it into gear and it stalled. Any help would be appreciated.
