78 KZ650 (putting a motor in myself)
  • BiggDogg
  • BiggDogg's Avatar Topic Author
26 Jun 2006 13:02
#57291
I got a good ? How can I put the motor/trans in the frame by myself safely?? I don't have my 350lb help anymore!!!I really want to get this big beafy bad boy back on the road...Thanks
  • wireman
  • wireman's Avatar
Re: 78 KZ650 (putting a motor in myself)
26 Jun 2006 13:07
#57293
wrap your frame up really good so you dont ding it up to bad,i always remove the exhuast studs to make it easier some dont though.
  • BiggDogg
26 Jun 2006 13:10
#57295
I also forgot to mention that I am not a big fella(stought wise):huh:
  • steell
  • steell's Avatar
26 Jun 2006 13:38
#57304
Some people lay the motor on the ground on it's side then lay the frame down over it. Others make some kind of table (cement blocks/bricks/etc, with a board on top), of the same height as the frame, set the motor on it and then slide it into place.
And there's always the "Invite a couple of friends over to share a sixpak" thing :)
  • wireman
  • wireman's Avatar
26 Jun 2006 13:52
#57309
if it was a bare frame id lay the motor on its side and lay frame over it and bolt it together,but it sounds like yours is complete.so id go heeman route.;)
  • BiggDogg
26 Jun 2006 14:58
#57318
Thanks for the help! I just kinda yanked it out the first time and I generisized all of your ideas and Woooop there it is! Thanks again...Wont be long now!!! HotDogg B)
  • bkitchen
  • bkitchen's Avatar
26 Jun 2006 20:40
#57416
I went through this same thing about a year ago. I am about 5'8" and 160lbs. so not"stout" either. I got it up on the frame and then used a couple of bars to lever it over little by little and into the right position. Just take it slow and always be aware of the strain you are putting on your back. (Lift with legs)
  • BiggDogg
26 Jun 2006 22:25
#57425
B) Yea I'm your size sept I got bout 15lbs on ya. She went in smooth thanks to all the help here! I love this place, I've never been on a board that has and gives so much help and information...Thanks everyone!;)
  • wiredgeorge
  • wiredgeorge's Avatar
27 Jun 2006 06:12
#57456
I like to use a square wheeled moving dolly and transmission jack. I WILL NOT lay a frame over on its side when I can just pop the engine off the dolly onto the transmission jack and let the jack lift the engine to the right height then just slip the engine into the frame. Then I slide the jack back under the engine and lift a little till the motor mounts line up and then bolt it up.
  • steell
  • steell's Avatar
27 Jun 2006 06:45
#57462
My nephew and I are both about the same size (6'3"+, 240 lbs), and I pick up the motor and hold it at chest height while he picks up the bike and slides it over the motor. He holds it while I bolt it in place :laugh: :laugh:
I'm joking, but we actually might be able to do that, he is into weight lifting and bench presses somewhere over 600 lbs. :)
Post edited by: steell, at: 2006/06/27 09:45
