Valve Clearance Adjustments
  • monroeraustin
  • monroeraustin's Avatar Topic Author
Re: Valve Clearance Adjustments
15 Mar 2013 16:02 - 16 Mar 2013 17:15
#577068
Ok.. this past weekend I did some adjustments and noted the info below.. I did swap out some of the shimms and since then rechecked the clearances and seems I might need to adjust more.. Please give feedback if needed.. Thanks.
Attachment ClearanceNotes.JPG not found
Seems the common number here is .15 but all except the # 7& 5 would need changing.. should I make more adjustments.. if so please advise the changes.. Thanks..
Last edit: 16 Mar 2013 17:15 by monroeraustin.
