ring installation
  • brianrae33
  • brianrae33's Avatar Topic Author
ring installation
14 Feb 2013 21:02
#572414
order four sets of rings from z1...the top ring is supposed to have a n mark or a dot on the upfacing side...and the website says the ring is chamfered...well..there is no mark and if there is a chamfer on the ring edge it must be so miniscule that you need a microscope to see it...any help greatly appreciated as i do not want to install them wrong...
1982 kz1000ltd
  • brianrae33
Re: ring installation
14 Feb 2013 21:12
#572415
just checked my service manual and it states top ring is symetrical and can be installed either way..
1982 kz1000ltd
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
14 Feb 2013 21:28
#572419
You can always call Z1 back and talk to their technical department. They are very knowledgeable and know their products.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • stewtam
  • stewtam's Avatar
22 Feb 2013 23:03
#573634
Had the same problem with rings from z1.I took them to a local motor cycle mechanic he could not find any marks or chamfer eather and said he didnt think it would matter which way it went so I put them on .No problems so far. Would be a good idea to contact z1 though.
