White smoke/ oil out of the airbox
  • Slowpoke
  • Slowpoke's Avatar Topic Author
10 Feb 2013 22:37
#571822
I just replaced the oil filter, put in the recommended amount of fresh oil, cleaned the carbs, and cleaned out the gas tank. Finally went to start it today and it idled for about a minute, then spit out white smoke like it was born to do it, and oil started POURING out of my airbox vents. It's on a 1980 KZ750 H model, with the inline 4. I'm so pissed right now, but need your guys' help. What the fuck just happened?
  • Old Man Rock
  • Old Man Rock's Avatar
Re: White smoke/ oil out of the airbox
10 Feb 2013 22:48
#571828
cleaned out the carbs and tank how (process/sea foam etc).....?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
The following user(s) said Thank You: Tomolu5
  • wireman
  • wireman's Avatar
10 Feb 2013 22:51
#571831
Check oil level in sight glass with bike straight up and down to see if its over filled,should be just below top line in sight glass B)
10 Feb 2013 23:31
#571848
Would also check for gasoline-contaminated oil in the crankcase.
Do the sniff-test, and also physically examine the oil.
Perhaps the recent carb work resulted in substantial volume of gasoline rising up into the carb throat (for whatever reason) and ultimately making its way into the crankcase.
Good Fortune! :)
  • donthaveakawman
  • donthaveakawman's Avatar
10 Feb 2013 23:51
#571858
Slowpoke wrote: I just replaced the oil filter, put in the recommended amount of fresh oil, cleaned the carbs, and cleaned out the gas tank. Finally went to start it today and it idled for about a minute, then spit out white smoke like it was born to do it, and oil started POURING out of my airbox vents. It's on a 1980 KZ750 H model, with the inline 4. I'm so pissed right now, but need your guys' help. What the fuck just happened?
do you think you switched the oil with the gas?
