ring compressors
- brianrae33
ring compressors
09 Feb 2013 17:03
anyone know where to get cheap ring compressors?
1982 kz1000ltd
- bountyhunter
Re: ring compressors
09 Feb 2013 18:13
I have a set of two good ones I bought to do my 750 twin. They wre not cheap, but since I'll never use them again, I might sell them cheaper than I paid.
Some people use hose clamps.
- Tomolu5
09 Feb 2013 19:25
I just used my fingers and some help from a popsicle stick to work them into the jug
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- wireman
09 Feb 2013 21:22
Theyre should be enough of a chamfer on bottem of sleeves to wrestle them in with your fingers carefully
- donthaveakawman
10 Feb 2013 03:34
yeah, try to get a piston ring compressor out of under the block.
10 Feb 2013 03:43brianrae33 wrote: anyone know where to get cheap ring compressors?
For a few other options --
Click > www.kzrider.com/forum/advsearch?q=piston...ldforums=1&catids=21
- bountyhunter
10 Feb 2013 05:24I did. I used small vise grips to clamp on the studs to gradually let the cylinder down. After all rings were in, I unlatched the ring clamps and slipped them off and removed the metal bands. Then I put the sealer on the base gasket and lowered the cylinder into place.donthaveakawman wrote: yeah, try to get a piston ring compressor out of under the block.
The "hand squeeze" method might work if you have more than one person to wrestle everything into place.
- donthaveakawman
10 Feb 2013 05:29
It shouldn't be such a problem because the bore is larger at the bottom.
- Old Man Rock
10 Feb 2013 10:03 - 10 Feb 2013 10:04
Sure do & cheap to... At the end of your arms...
Follow the link past your elbows-> wrists-> hands-> fingers....
These two sets of tools work like magic on rings and such every time with track record proven results...
They can be used for 2, 3 or 4 cylinder ring compressions. Best part they're FREE!
Now if you still feel the need to have a different tool... Ace, Home Depot, Lowes have thin rolled aluminum or steel material (soda can wall thickness) that could be used as well... Slide out from top of cylinder hole.
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 10 Feb 2013 10:04 by Old Man Rock.
10 Feb 2013 12:24 - 10 Feb 2013 12:26
Here, for reference, is the piston ring compressor that's included among Kawasaki's "special tools."
Last edit: 10 Feb 2013 12:26 by Patton.
- lushbaugh
- everybodys a pro......
10 Feb 2013 21:27
if you wanna get hyper cheap pop can aluminum or really any thin metal and a hose clamp, i have a few good ones but i use them alot. most of the time a high dollar ring compressor is honestly overkill anyway.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- donthaveakawman
