KZ650 SR wheel questions
- Danielmccarty1
07 Feb 2013 10:48 #571263
by Danielmccarty1
1979 KZ650 SR
KZ650 SR wheel questions was created by Danielmccarty1
Hello all..I am trying to find options for upgrading the rims on my 79 KZ650 SR. The bike currently has mags (19" front, 16" rear). I would like to convert to spoke wheels if possible, maintain the 19" on front and increase the size of the rear wheel to 18". Does anyone have any experience in this area? Is it a job that requires extensive modifications? Will I need to switch from disc to drum brakes? Secondly, if converting the wheels from mags to spokes turns out to be a job I'm not willing to undertake, is upgrading the rear mag to 18" (as on the KZ650 custom) a direct swap. The KZ650 C has a 220mm single disc brake, exact same as my SR650. I would appreciate any help/guidance any of you can offer. Thanks.
1979 KZ650 SR
- Thank you received: 2829
07 Feb 2013 11:19 #571270
by 650ed
Replied by 650ed on topic KZ650 SR wheel questions
I don't believe any KZ650 model came with a rear disk on a wire wheel, so if you switch to wire you might need to switch to drum unless you can find a wire/disk combo from a different bike. Also, keep in mind that the torque link (that bar that runs from the brake to the swing arm) is different between drum and disk brake bikes. On the disk models it attaches to the top of the swingarm; on the drum it attaches underneath the swingarm. So if you switch to a drum brake you will need to move the torque link mount or swap swingarms, and you will need to deal with the different brake pedal setup since the drum uses a rod rather than a master cylinder. The rear axles of the SR and C models are the same part number; but the spacers/collars are different, so at the very least you will need to get all the bits and pieces from the C model if you swap to the C model 18" cast wheel. It may be easier just to swap out the whole swingarm if you can find one at a good price. The SR and C swingarm pivots (where they attach to the frame) are the same part number. Ed
- Danielmccarty1
07 Feb 2013 20:39 #571354
by Danielmccarty1
1979 KZ650 SR
Replied by Danielmccarty1 on topic KZ650 SR wheel questions
Thanks Ed. I appreciate your help. I like the idea of finding an affordable c model swing arm and rear wheel.
If anyone who reads this has topic is selling a 650 c rear swing arm and rear wheel please let me know and send me pics if possible.
1979 KZ650 SR
- wireman
- Thank you received: 299
07 Feb 2013 20:52 #571358
by wireman
Replied by wireman on topic KZ650 SR wheel questions
Find somebody parting out a 750 twin ,they used wire wheels with front/rear disc brake.
Your front brakes should be a direct swap to the wire wheel but you might want to get the wheel spacers just incase.
The rear wheel might require a bearing swap to fit the 650 axle,not sure if 650/750 use same diameter axle or not(I know the 1000 axle is bigger)
Again get the wheel spacers and any other parts for rear of 750 you can just incase,750 swingarm may have same width at the pivot and length as 650 Im not sure .
- Thank you received: 2098
07 Feb 2013 21:25 - 07 Feb 2013 21:26 #571369
by Patton
Replied by Patton on topic KZ650 SR wheel questions
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part
, availability, etc. Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Last edit: 07 Feb 2013 21:26 by Patton.
- rstnick
- Thank you received: 377
07 Feb 2013 21:54 #571378
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic KZ650 SR wheel questions
Welcome Daniel.
What area are you in?
Add that info, and your bike's model to a signature line.
I may have some parts if you go the C model route.
Have a look here kz650.info/ too.
Lots of 650 owners who may have parts available.
Post up some pix too.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
