Help Identify these Pistons Please
- wireman
Re: Help Identify these Pistons Please
07 Feb 2013 00:55
Im guessing the big F means front,Or just go by the valve notch sizes
- z1kzonly
07 Feb 2013 01:06Don, you need to tighten your fan belt and buckle! Do that after you grease your muffler bearings.donthaveakawman wrote: do you remember what way those were in there?
While your at it, check your kanutin valve.
Let us know how you do.
- wireman
07 Feb 2013 01:08
:laugh: :laugh: :laugh: :laugh: :laugh:
07 Feb 2013 01:24 - 07 Feb 2013 01:26
I did a search and found an obsolete eBay listing that states:
"NEW Piston CB750 Big Bore Kit Piston 900CC Haindt TOHO 67."
See: www.google.com/#hl=en&sugexp=les%3B&gs_r..._gc.r_pw.r_qf.&cad=b
and I found an image showing this:
www.google.com/imgres?imgurl=http://thum...z6oHoCQ&ved=0CDwQ8g0
Last edit: 07 Feb 2013 01:26 by 650ed.
- davem
07 Feb 2013 15:46Ok I measured. Got some mixed readings. Probably the cheep harbor freight caliper.z1kzonly wrote: Did you ever tell us the bore? Is it stock 1015cc or 1075cc? Maybe 1045cc?
Just measure the thickness of the top and middle rings.
Probally the same as Wiseco or MTC. 1 ring is cast iron, other one is chromed on the edge.
Oil scrapers are all the same.
Plus Hastings makes custom rings too.
Start measuring! Go buy a cheap Harbor Frieght digital venier caliper.
The top ring is 2.945 next one down is 2.98.
Measured the cylinder it was 2.834
Piston measured very top right above first ring 2.81 after first ring 2.808 bottom of piston 2.832 2.834 2.835. This is where I got mixed readings.
There are some wear marks on side of piston and insided the cylinder.
And I just found a hair line crack in cylinder see picture. What is my next step here? Can that be fixed?
Attachment 20130207_134246.jpg not found
Attachment 20130207_134242.jpg not found
1979 Kz1000 B3 LTD
1997 Kawasaki police 1000
1985 kz1000p4 project-sold
- davem
07 Feb 2013 15:51Ok I measured. Got some mixed readings. Probably the cheep harbor freight caliper.z1kzonly wrote: Did you ever tell us the bore? Is it stock 1015cc or 1075cc? Maybe 1045cc?
[attachment:1]C:\fakepath\20130207_134246.jpg[/attachment]
[attachment:2]C:\fakepath\20130207_134242.jpg[/attachment]
1979 Kz1000 B3 LTD
07 Feb 2013 15:57
that seems to be a 1075 size.
so i would just grab some stock cylinders and have them bored to match the pistons,buy some custom hastings rings and rebuild it.
thats my .02 fwiw,
thats my .02 fwiw,
- donthaveakawman
07 Feb 2013 21:52no need for that kin of swearing, pal.z1kzonly wrote:Don, you need to tighten your fan belt and buckle! Do that after you grease your muffler bearings.donthaveakawman wrote: do you remember what way those were in there?
here are some muffler bearings on sale if you didn't believe me.
kalecoauto.com/index.php?main_page=product_info&products_id=48
