case sealer
  • shadow44
  • shadow44's Avatar Topic Author
case sealer
04 Feb 2013 22:27
#570795
OK I got the factory recommended threebond case sealer and went to put the case together. That stuff dries too fast. it was almost dry before I got the 2 together. then I broke a main bearing bolt. so I am on hold I ordered some APE main studs, but my question is... Has anyone used Loktite 518 alum flange sealer? It looks like thick grape jelly. I have used it on small air cooled engines, it what Kohler recommended back years ago when i went to their tech school. I think it would have a longer handling time, and would rather use it but I dont want any case leaks. Anyone have first hand experience?
Remember, the government can not give you anything they have not first, taken from someone else.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: case sealer
04 Feb 2013 22:30 - 04 Feb 2013 22:35
#570797
I use this stuff...... B)
Last edit: 04 Feb 2013 22:35 by 4TheKZ1000.
  • dbc92s10
  • dbc92s10's Avatar
Re: case sealer
04 Feb 2013 22:36 - 04 Feb 2013 22:39
#570799
i use anarobic sealer like locktite 515 part no 51531 it only sets up where it gets compressed
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
Last edit: 04 Feb 2013 22:39 by dbc92s10.
  • shadow44
Re: case sealer
04 Feb 2013 22:37
#570801
Belt Dressing ? LOL you just like the girl on the label :woohoo:
LOL where do you get that stuff?
  • shadow44
Re: case sealer
04 Feb 2013 22:38
#570802
Did you get my PM?
  • dbc92s10
  • dbc92s10's Avatar
Re: case sealer
04 Feb 2013 22:42
#570803
yes just got it
81 ltd1000
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
Re: case sealer
04 Feb 2013 22:45
#570805
Which threebond did you use? They make several flavors. Ed
  • 4TheKZ1000
Re: case sealer
04 Feb 2013 22:51
#570807
shadow44 wrote: Belt Dressing ? LOL you just like the girl on the label :woohoo:
My bikes dont leak a drop.....intill they start leaking....im going to keep using it.
  • zukdave
  • zukdave's Avatar
Re: case sealer
04 Feb 2013 23:46 - 04 Feb 2013 23:48
#570818
Hondabond is what I use at work and
never have come backs because of case leaks.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 04 Feb 2013 23:48 by zukdave.
