Bike wont find neutral when idling...?
- Johnny5
25 Jun 2006 15:08
Say I ride the bike up and down the road and stop in the driveway. I go to find neutral to shut the bike down but I cant. It wont even tap into 2nd. I shut the engine off and then I can easily pop into neutral. Is there a reason for this?
The bike's a 75 KZ400.
Thanks
Thanks
- wireman
Re: Bike wont find neutral when idling...?
25 Jun 2006 16:50
have you tried adjusting clutch?;)this is for the neutral issue only.:whistle:
Post edited by: wireman, at: 2006/06/25 20:48
- steell
25 Jun 2006 17:29
It won't shift into second unless the bike is moving, that's Kawasaki's patented "Neutral Finder" feature
Just so you know why it still won't shift into second when you are sitting still after you get the current problem fixed.
- The Milkman
25 Jun 2006 19:58
Are you downshifting into first as you are coming to a stop?
- Corith
26 Jun 2006 07:46
The Kawasakis can only shift into 1st and Neutral when the rear tire is not rotating. So when you pull into a driveway, do this:
1. Shift all the way down into first.
2. Shift "up" once.
You'll THINK you're in second, but as long is everthing is working correctly you'll be in neutral.
3. Now kill the engine.
4. Release the clutch.
5. And try and move the bike. Does it move without the clutch? If so, you're in neutral.
2. Shift "up" once.
- guitargeek
26 Jun 2006 12:32
When I can't find neutral I put it first gear and apply the front break, then ease off the clutch a little (just enough to put a load on the transmission). Reel in the clutch and it goes right into neutral.
I'll have to try it the other way...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- apeman
27 Jun 2006 10:18
Corith wrote:
I do not believe this is accurate, at least as far as my bikes are concerned. I downshift into first and use compression braking as I am approaching a stop (stop sign or red light) almost every time. I have also accidentally shifted into neutral when shifting lazily between 1st and 2nd while traveling at low speed. Very aggravating when I roll on the throttle, and there is nothing to the back wheel.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- wireman
27 Jun 2006 10:24
what he was saying is you cannot shift into 2nd gear when bike is sitting still,it is possible to hang up between gears when shifting,thats why i dont use clutch so i only have to concentrate on what my foot is doing.:evil:
- steell
27 Jun 2006 10:58
Explanation is
HERE
because I don't feel like wearing out my two typing fingers
