cams
- brianrae33
cams
02 Feb 2013 22:46
quick question..currently runnung cams from an 82 gpz...just curious as to whether or not the larger cam should be in the intake or the exhaust??
1982 kz1000ltd
- wireman
Re: cams
02 Feb 2013 22:50
Intake
- 4TheKZ1000
Re: cams
02 Feb 2013 22:52
On street bikes you run the same lift....when you get into serious race bikes you will see the different cams come into play. I really dont think you would benifit from it at all.
- brianrae33
Re: cams
02 Feb 2013 23:21
so id be better off with the stock cams...and are the stock 82 1000 cams the same? meaning lift on intake and exhaust??thanx for any input..
1982 kz1000ltd
- 4TheKZ1000
Re: cams
02 Feb 2013 23:52
Im not sure if you have a matched set or not. I think they are but could be wrong. Why did you ask where the larger cam goes?
- Mcdroid
- Gone Kwackers
Re: cams
03 Feb 2013 04:22 - 03 Feb 2013 04:26
The 1982 GPz1100 (aka KZ1100-B2) cams (IN and EX) have identical profiles. The only difference is how they mount in the cam sprockets (= cam timing). Brianrae33, if your cams have different profiles, then you have a mixed set of cams or something other than 1982 GPz camshafts.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 03 Feb 2013 04:26 by Mcdroid.
- donthaveakawman
