interchangable valves
- johkyls
01 Feb 2013 01:10 #570191
by johkyls
interchangable valves was created by johkyls
Hey all, I have an australian Z500 that is missing the exhaust valves & springs, I cannot find any without spending what the bike is worth! will valves & springs from a KZ550 fit? I have seen used ones on ebay for less than $100(valves & springs) or am I up $#it creek. any info would be great.
Thanks John
Cheers & Burbons
Thanks John
Cheers & Burbons
- wireman
- Thank you received: 299
01 Feb 2013 01:22 #570194
by wireman
Replied by wireman on topic interchangable valves
What year of bike do you have?
- wireman
01 Feb 2013 02:15 #570199
by wireman
I wonder if a complete 550 cylinder head wouldnt drop on there,what year is it?
- Motor Head
- Thank you received: 391
01 Feb 2013 11:01 - 01 Feb 2013 11:36 #570230
by Motor Head
Replied by Motor Head on topic interchangable valves
If you have the head off, measure the valve size. Compare to the 550, probably the same as Wireman stated. Then it will be easy to get them, just some freight to OZ.
This from the Vesrah website. KZ550LTD, 80-83
Last edit: 01 Feb 2013 11:36 by Motor Head.
- johkyls
01 Feb 2013 18:17 #570270
by johkyls
Replied by johkyls on topic interchangable valves
Hey wireman, I have an 81 with engine no. kz500ae015166. there is a listing for valves from an 81 550 on ebay also springs listed from the same bike, I am reluctant to purchace these as I have read that the 550 had larger valves but also read they only had diffrent valve timing, I cannot get a definate answer! problem is I dont have the old valves to measure. my manual only states a 'seating area' not actual size. I have found these part no's
12005-5001(early 78-81)
12005-1013(late 81-onwards) I am not 100% sure these are correct
Thanks for any advice
John
Cheers & Burbons
John
Cheers & Burbons
- wireman
01 Feb 2013 19:38 #570286
by wireman
I posted the same question on the z1gb site to see if we can find an answer for ya
- wireman
01 Feb 2013 23:25 #570315
by wireman
Well according to the fabricating genius zed 1015 the 500-550 motors are same other than stroke.
So if you can find a complete decent priced complete 550 head it may save you from having to have a valve job done atleast.
- johkyls
02 Feb 2013 02:15 #570336
by johkyls
Hey Mr wireman, THANKYOU for your trouble, I finally have a road to travel!!!!!! :woohoo:
I will prob purchace valves & springs and have my head done as postage from the USA would be lots for a complete head that would need to be reconed anyway.
I am thinking around $500 for the job.
Again THANK YOU very much
Cheers & Burbons
John
Cheers & Burbons
John
