Cam End Plugs.....engine removal?
  • w8lifter21
  • w8lifter21's Avatar Topic Author
  • Automotive Afficianado
25 Jan 2013 13:29
#569215
I think the time has come to finally get these replaced. Question is, does the motor have to be pulled for this job? If memory serves me right I think there should be enough space, but not 100% sure. When getting these replaced, are there other things/items I should consider replacing as preventive maintenance? '82 750 4cyl with 10k
'82 Kawayamazuki 750 (KZ750)
'91 300zx Twin Turbo
'96 Maxima
Re: Cam End Plugs.....engine removal?
25 Jan 2013 14:01
#569217
The motor stays in place. Just pull the valve cover off, replace them, and pop it back on. It's an easy task. Use a little sealant where the curved section of the plug mates with the cylinder head. Ed
  • baldy110
  • baldy110's Avatar
25 Jan 2013 15:29
#569221
By you asking that question leads me to believe you have never done a valve check / adjustment on tath engine, it has 10,000 miles on it. The recommended valve check intervals for that bike are 3,000 miles. If you are going to replace those end plugs might as well check the valve clearance.
  • wireman
  • wireman's Avatar
25 Jan 2013 15:46
#569225
Those style caps have the bolts through them so blow outs shouldnt be a problem,Id clean them up and reinstall with a little 3bond around the curved part and new valve cover gasket after checking valves B)
  • w8lifter21
25 Jan 2013 16:33
#569231
baldy110 wrote: By you asking that question leads me to believe you have never done a valve check / adjustment on tath engine, it has 10,000 miles on it. The recommended valve check intervals for that bike are 3,000 miles. If you are going to replace those end plugs might as well check the valve clearance.
Thanks for the info I definitely haven't.
Guess I better start printing off pages from the manual :)
'96 Maxima
  • w8lifter21
25 Jan 2013 16:36
#569236
wireman wrote: Those style caps have the bolts through them so blow outs shouldnt be a problem,Id clean them up and reinstall with a little 3bond around the curved part and new valve cover gasket after checking valves B)
So don't bother replacing them? I can see the corners of the 1/2 moon shape starting to "curl" out away from the motor so I assumed they were starting to come out. After a few hundred miles I have light oil build up on the heat sinks. Not quite to a drip yet but there's definitely oil making its way out. I figured for $15 why not lol.
'96 Maxima
25 Jan 2013 17:03
#569239
Wireman is right that they won't blow out, but they get hard as diamonds and shrink some after a while, so I would go ahead and replace them. Make sure you have a new valve cover gasket on hand; you may need it. Ed
  • w8lifter21
25 Jan 2013 17:08
#569240
Ah, very true. I have come across many rock hard rubber parts under the scortching hot hood of my 300zx.
'96 Maxima
  • APE Jay
  • APE Jay's Avatar
25 Jan 2013 17:32
#569246
You can replace those without removing the cylinder head?
  • wireman
  • wireman's Avatar
25 Jan 2013 18:22
#569249
Yep just pull the valve cover off Jay,those are the style you guys dont make.
Is it the bolt going through the center that makes it tough to get a seal in there to seal aluminum ones Jay?
I always figured that was why you guys didnt make them B)
  • APE Jay
  • APE Jay's Avatar
26 Jan 2013 04:06
#569344
I was just kidding. We never made those because I didn't think there would be enough of a market for them.
  • zukdave
  • zukdave's Avatar
26 Jan 2013 17:34
#569381
Jay what would be a min. run you would have to
make on some low volume part's ?
Say maybe these or a low pro. oil filter cover
for the small four's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
