aftermarket cams?
  • toad
  • toad's Avatar Topic Author
aftermarket cams?
25 Jan 2013 00:57 - 25 Jan 2013 11:49
#569126
I have a cm z5 intake(.429) and my exhaust cam measures .410 but I cannot find any markings on the end only on top beside the sprocket with this stamping 7 FC30.I think these are the correct letters a little hard to make it out.Would anyone have any ideas who manufactured this cam?I tried researching but was unable to decipher.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Last edit: 25 Jan 2013 11:49 by toad. Reason: pic
  • wireman
  • wireman's Avatar
Re: aftermarket cams?
25 Jan 2013 02:13
#569159
Pm Larry Cav or APE Jay B)
  • toad
25 Jan 2013 12:58
#569208
ok will do..
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
25 Jan 2013 13:13
#569212
I have heard and seen that the cams are marked on the sprocket bosses.
Remove the chain sprockets and see if they are marked.
stamping 7 FC30 is just the pre-profile blank number that the manufracture uses.
Larry and Jay would be your best bet as Wireman said.
  • toad
25 Jan 2013 14:15
#569218
7025.40 is also stamped on top of the sprocket carrier.thanks I missed that.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
The following user(s) said Thank You: 4TheKZ1000
  • Sorf
  • Sorf's Avatar
25 Jan 2013 21:24
#569273
Hi toad, if you manage to find anything out, post it up. I also have a set with 3.1 7035 stamped beside the sprocket I'd like to get info on.
  • toad
26 Jan 2013 12:39
#569362
My assumption is they are Mega Cycle but there numbers start with a 47025,mine say 7025.40 and I cannot find 7035 advertised. Still searching!
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
