What do the large O rings do at the base of the cy
  • 3cav84a
  • 3cav84a's Avatar Topic Author
17 Jan 2013 07:38
#567854
As it says in the subject what do they actually do. When I pulled the motor apart they were just sitting there sort of doing nothing, what do they do? any ideas, regards Neil
1977 KZ 1000 A1
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
Re: What do the large O rings do at the base of the cy
17 Jan 2013 07:58
#567855
supposed to keep oil from leaking out of the jug base....supposed.....
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
17 Jan 2013 08:13
#567858
Yep...they stop oil creeping up the outside of the cylinder sleeves. Kawasaki put them there for a reason and aftermarket gasket kits include them. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • APE Jay
  • APE Jay's Avatar
18 Jan 2013 02:34
#567976
But when the oil goes up the outside of the sleeve, it can't go anywhere.
On all the big sleeve setups we do, there are no o'rings in there and it has never been a problem
  • Old Man Rock
  • Old Man Rock's Avatar
18 Jan 2013 08:55
#567991
Permatex "Black" Gasket Sealer.... Works just fine in place of the red rubber O-rings!.... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Motor Head
  • Motor Head's Avatar
18 Jan 2013 10:11
#567998
APE Jay wrote: But when the oil goes up the outside of the sleeve, it can't go anywhere.
If oil does get between the cylinder sleeve and the engine block, wouldn't it just help transfer heat from the sleeve to the block? With the Head gasket in place, and the fit of the sleeve upper land. I can't see a oil leak at the upper area of the sleeve.
The "" motor has No O-ring at the base, just the gasket.
