aftermarket clutch/clutch springs
- donthaveakawman
16 Jan 2013 23:05Attachment get-attachment5.jpg not found
curious about my clutch, I occasionally get some slipping either in the tire or the clutch, yesterday on the freeway i dropped it into 3rd and the tach went off the wall when I opened the throttle. I am curious about stronger clutch spring, which are available for a fair price. from what I understand they should be at least replaced when changing the clutch
Attachment get-attachment7.jpg not found
Re: aftermarket clutch/clutch springs
16 Jan 2013 23:17
I would first adjust the clutch using the instructions in the manual. Very often that will solve the problem. The stock clutch springs are normally strong enough for stock engines. If you install heavy duty or racing springs you may find the clutch lever becomes tiring in traffic. Ed
- donthaveakawman
16 Jan 2013 23:19
tighten adjusting screw and back it out a half turn, uh huh. I do think it would be a hassle to have stiffer springs in traffic that may be a pain.
16 Jan 2013 23:26 - 16 Jan 2013 23:26
Make sure the central cable adjuster and the nut at the lever are also adjusted correctly. Another issue you could be experiencing is moly or some other "Friction Modifier" building up on your clutch plates if automotive (Energy Conserving) motor oil has been used instead of oil that is JASO-MA compliant.
Heavy duty clutch springs can be a real pain in the wrist in traffic. My old BSA ended up with a factory competition racing engine (long story) and that clutch was murder to use in traffic. Ed
Last edit: 16 Jan 2013 23:26 by 650ed.
The following user(s) said Thank You: guitargeek
- zukdave
17 Jan 2013 00:35 - 17 Jan 2013 00:37
lose nut just behind the steering stem seems to be the issue.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 17 Jan 2013 00:37 by zukdave.
The following user(s) said Thank You: guitargeek, Lorcan, wireman, Street Fighter LTD
- lushbaugh
- everybodys a pro......
17 Jan 2013 06:40650ed wrote: Make sure the central cable adjuster and the nut at the lever are also adjusted correctly. Another issue you could be experiencing is moly or some other "Friction Modifier" building up on your clutch plates if automotive (Energy Conserving) motor oil has been used instead of oil that is JASO-MA compliant.
its amazing there are still guys like you who try to help him, i gave up on it after the exhaust crud thread. you must be a nice guy. and im posting to say plus one on adjustment and wear preventitive additives in oil, i had a guy bring me a gsxr that would slip horribly, after adjusting what i could and checking the plates we figured out he was using a big brand hi milage type oil. keep up the great advice, most people have no clue about the oil.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- Powerstroke_fan
17 Jan 2013 09:11
I remember reading in another post where he said he added some type of oil stablizer believe he said it was lucus.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- lushbaugh
17 Jan 2013 09:15bingoPowerstroke_fan wrote: I remember reading in another post where he said he added some type of oil stablizer believe he said it was lucus.
- Lorcan
- Speed Loony
17 Jan 2013 09:17donthaveakawman wrote: curious about my clutch, I occasionally get some slipping either in the tire or the clutch, yesterday on the freeway i dropped it into 3rd and the tach went off the wall when I opened the throttle.
That will be those 85 horses breaking free... :whistle:
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- lushbaugh
17 Jan 2013 11:33 - 17 Jan 2013 11:41Lorcan wrote:donthaveakawman wrote: curious about my clutch, I occasionally get some slipping either in the tire or the clutch, yesterday on the freeway i dropped it into 3rd and the tach went off the wall when I opened the throttle.
ALL 85 you say? :pinch: sounds like danger. id bet a bike like that would blow tires to peices....
www.kzrider.com/forum/13-bike-related/49...-cost-my-entire-life
Last edit: 17 Jan 2013 11:41 by lushbaugh.
- Powerstroke_fan
17 Jan 2013 12:49lushbaugh wrote:Lorcan wrote:donthaveakawman wrote: curious about my clutch, I occasionally get some slipping either in the tire or the clutch, yesterday on the freeway i dropped it into 3rd and the tach went off the wall when I opened the throttle.
And your shoes too :woohoo:
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- gpz1170
17 Jan 2013 15:13
how fast were you going when you "dropped" it in 3rd
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
