Reed Valve Oil Leak
  • Spectre1982
  • Spectre1982's Avatar Topic Author
Reed Valve Oil Leak
14 Jan 2013 21:20
#567371
I'm removing the air suction system on my KZ750. Inside the hose there was a couple tablespoons worth of oil. Underneath the air suction valve covers both sides look oily. One side looks pretty clean, the other side has black burned up oil. A little bit of oil was dribbling from the air suction valve covers this season. Anybody know what's going on? My oil level looks normal, not too full.
Thanks
I can snap some photots tomorrow if I'm being unclear.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
  • Motor Head
  • Motor Head's Avatar
Re: Reed Valve Oil Leak
14 Jan 2013 23:51
#567386
Pictures always help, so post some up. Any signs of oily residue on any of the spark plugs? If not, then its probably valve stem oil seals. They will leak into the exhaust port, and a reed valve for the fresh air system can have it push up past the reed if it doesn't seal. The reed should be a one way check valve, only letting air in, not exhaust out. If you pull you EX off at the head you can see if the stem seals are leaking.
  • donthaveakawman
  • donthaveakawman's Avatar
15 Jan 2013 00:21
#567390
maybe the fitting in the airbox is screwed up where the crankcase ventilation sits right next to the clean air/reed valve vacuum hose. mine are acting funny also, idling in the driveway I can hear them tap,tap,tap with suction going into the hose. I have pod filters now and no way to use the vacuum hose on my 750 so it just sits under the gas tank.
  • Spectre1982
15 Jan 2013 16:03 - 15 Jan 2013 16:10
#567492
Here's a couple of pics. As you can see, one is pretty burned up looking.
After more thought my theory is oil came up from the crankcase breather, got pulled into the air suction system and worked its way down to the reed valve area. I'm assuming there's not supposed to be oil in there. The oil level is pretty close to the high marker. maybe too much oil? Can oil get flung up from the cam past the reeds?
Hopefully removing the air suction system will fix any leaking oil since it can't suck any more through.
1978 Kawasaki KZ200
Last edit: 15 Jan 2013 16:10 by Spectre1982.
  • donthaveakawman
15 Jan 2013 17:38
#567514
did you check the oil level?
  • donthaveakawman
20 Jan 2013 22:37
#568390
I plugged my vacuum system and it runs like crap.
  • zukdave
  • zukdave's Avatar
20 Jan 2013 22:54
#568397
donthaveakawman wrote: I plugged my vacuum system and it made my B/F real mad
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
