810cc wiesco kit
- souljur412
14 Jan 2013 07:31 #567295
by souljur412
810cc wiesco kit was created by souljur412
Okay brothers,,,I'm seriously considering hypo'n my 83 ZX750,,,,the whole enchilada too. oversize the piston,milling the head and carbing it....My question? has anyone out there done this and is it worth it?..... fill a brother in....
- Powerstroke_fan
- Thank you received: 83
14 Jan 2013 09:33 #567303
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic 810cc wiesco kit
People build 810 motors not sure on your year in specific. But not to be rude but if you want more power have you ever considered buying a 900 or 1000 or bigger bike?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- steell
14 Jan 2013 13:36 #567324
by steell
Replied by steell on topic 810cc wiesco kit
Several others here have done it, and been very happy with the results.
Check out member turboguzzy's posts, he races a 750.
- souljur412
14 Jan 2013 21:24 #567372
by souljur412
Replied by souljur412 on topic 810cc wiesco kit
Hey powerstroke,,,I have bigger bikes with this one it's about having one of the original rockets, by the way I started riding street in 83, and taking that O.G. bike and making it compete with these new bikes that the rider only relies on h.P. to win,,, you should sewe the looks i get on my GPZ750 it still is beautiful to see...
- Powerstroke_fan
14 Jan 2013 22:28 #567377
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ya iam a sucker for all the old kaws. I am sure theres alot of good people to help guide you in the correct direction
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
The following user(s) said Thank You: souljur412
- Lorcan
- Speed Loony
- Thank you received: 59
16 Jan 2013 11:22 #567663
by Lorcan
Plenty of people have done it and the Wiseco kit is known to perform well. Do some searching and reading on here. Whether you feel it is worth it is down to your individual perspective. Tuning a bike costs time and money, but you do get to learn and some people enjoy that more than just buying a more powerful bike. If it interests you and you can afford to do it (in both time and money terms) then do it. You don't need to know anything before you start. We all started off knowing nothing...
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
Replied by Lorcan on topic 810cc wiesco kit
souljur412 wrote: Okay brothers,,,I'm seriously considering hypo'n my 83 ZX750,,,,the whole enchilada too. oversize the piston,milling the head and carbing it....My question? has anyone out there done this and is it worth it?..... fill a brother in....
760cc - 8.69@162mph
The following user(s) said Thank You: wireman, souljur412
- 4TheKZ1000
- Visitor
16 Jan 2013 12:34 - 16 Jan 2013 12:38 #567667
by 4TheKZ1000
Replied by 4TheKZ1000 on topic 810cc wiesco kit
I read your first post. You wanted the following.
Oversize Pistons.
Milling The Head.
Why would you mill the head? If your trying to raise compression, most piston kits like Wiseco will raise compression 2 points with no need to mill head.
A performance upgrade is done to provide two basic things....more air and more fuel in and out of the engine creating increase of HP and torque.
I have not heard you mention the performance adds below to name a few. Not all need to be done but should be considered.
1. Carbs. (You did mention)
2. Cams.
3. Header.
4. Porting Of intake / exhaust ports.
5. Air Cleaner Pods.
6. Proper Oil / Gas.
7. Setting Up Crankshaft.
8. Electrical Wiring Harness Condition.
9. Electronic Ignition.
10. Coils.
11. Spark Quality.
12. Head Work / Valve Guides / Valves / Valve Clearance.
You need to think about this, talk to people who have been there, read material and call experts comming up with a solid plan. These performance items are very exspensive and need to be selected in a certin order to work properly. Many on here will be glad to help.
Oversize Pistons.
Milling The Head.
2. Cams.
3. Header.
10. Coils.
11. Spark Quality.
Last edit: 16 Jan 2013 12:38 by 4TheKZ1000.
