Alt rotor removal
  • Powerstroke_fan
  • Powerstroke_fan's Avatar Topic Author
Alt rotor removal
13 Jan 2013 15:04
#567158
Does anyone know what size bolt it takes to remove the rotor on a mk11 crank?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • wireman
  • wireman's Avatar
Re: Alt rotor removal
13 Jan 2013 15:39
#567168
Rear axle bolt or possibly top triple tree bolt,you need to have the right size ball bearing behind it though B)
  • Powerstroke_fan
13 Jan 2013 15:40
#567170
Ill have to find a couple laying round somewhere thanks jim
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
  • wireman
  • wireman's Avatar
13 Jan 2013 15:49
#567178
Da nada,Carefull which ball bearing you use B)
  • Powerstroke_fan
13 Jan 2013 15:51
#567180
Ok should i use the biggest ball bearing that will fit in there? Or what?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
  • wireman
  • wireman's Avatar
13 Jan 2013 15:55
#567184
Yes,biggest one you can fit in there so threads in crank don't get chewed up B)
Ive got extra axle bolts if you don't have one B)
  • Powerstroke_fan
13 Jan 2013 15:59
#567185
I should have a couple laying around, But right now finding anything is about impossible. Iam in the process of moving all my stuff from my work space to a garage so everything is everywhere.lol
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
