Oil pressure switch thread size?
  • Powerstroke_fan
  • Powerstroke_fan's Avatar Topic Author
11 Jan 2013 09:19
#566825
Does anyone know what the thread size the oil pressure switch is?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • wireman
  • wireman's Avatar
Re: Oil pressure switch thread size?
11 Jan 2013 10:34
#566834
Are you talking about the plastic piece? B)
  • Motor Head
  • Motor Head's Avatar
11 Jan 2013 11:21
#566843
I'm sure its a straight thread and Not a tapered Pipe thread. Haven't measured it, but 8 x 1.0 mm is a common switch thread. Otherwise 1/8" pipe is the common Tapered thread.
  • Powerstroke_fan
11 Jan 2013 18:54
#566886
wireman wrote: Are you talking about the plastic piece? B)
Yes
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
  • baldy110
  • baldy110's Avatar
23 Jan 2013 00:36
#568759
Did you ever find out the thread size and are you talking about the sending unit for the KZ1000?
  • Powerstroke_fan
23 Jan 2013 09:18
#568801
I didnt but i dont need it. Thanks,eric
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
  • baldy110
  • baldy110's Avatar
23 Jan 2013 13:14
#568823
But I do. Anyone
  • baldy110
  • baldy110's Avatar
24 Jan 2013 13:02
#568963
Cmon guys someone has to know the answer to this. I know it is 20mm x ??.
24 Jan 2013 15:50 - 24 Jan 2013 15:55
#568981
baldy110 wrote: Cmon guys someone has to know the answer to this. I know it is 20mm x ??.
As to KZ900 --
20mm thread diameter
15mm thread length
1.5mm thread pitch
Good Fortune! :)
Last edit: 24 Jan 2013 15:55 by Patton.
24 Jan 2013 16:02
#568982
According to kawasaki.com, oil pressure switch part number 27010-1013 is still an "active" part, and is common to the following Kawasaki models:
Model (62):
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D1 (Z1R) (1978)
KZ1000-D3 (Z1R) (1980)
KZ1000-E1 (Shaft) (1979)
KZ1000-E2 (Shaft) (1980)
KZ1000-G1 (Classic) (1980)
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)
KZ1000-K1 (LTD) (1981)
KZ1000-K2 (LTD) (1982)
KZ1000-M1 (CSR) (1981)
KZ1000-M2 (CSR) (1982)
KZ1000-P1 (Police 1000) (1982)
KZ1000-P10 (Police 1000) (1991)
KZ1000-P11 (Police 1000) (1992)
KZ1000-P12 (Police 1000) (1993)
KZ1000-P13 (Police 1000) (1994)
KZ1000-P14 (Police 1000) (1995)
KZ1000-P15 (Police 1000) (1996)
KZ1000-P16 (Police 1000) (1997)
KZ1000-P17 (Police 1000) (1998)
KZ1000-P18 (Police 1000) (1999)
KZ1000-P19 (Police 1000) (2000)
KZ1000-P2 (Police 1000) (1983)
KZ1000-P20 (Police 1000) (2001)
KZ1000-P21 (Police 1000) (2002)
KZ1000-P22 (Police 1000) (2003)
KZ1000-P24 (Police 1000) (2005)
KZ1000-P3 (Police 1000) (1984)
KZ1000-P4 (Police 1000) (1985)
KZ1000-P5 (Police 1000) (1986)
KZ1000-P6 (Police 1000) (1987)
KZ1000-P7 (Police 1000) (1988)
KZ1000-P8 (Police 1000) (1989)
KZ1000-P9 (Police 1000) (1990)
KZ1000-R1 (Eddie Lawson Replica) (1982)
KZ1000-R2 (Eddie Lawson Replica) (1983)
KZ1100-A1 (Shaft) (1981)
KZ1100-A2 (Shaft) (1982)
KZ1100-A3 (Shaft) (1983)
KZ1100-B1 (GPz) (1981)
KZ1100-D1 (Spectre) (1982)
KZ1100-D2 (Spectre) (1983)
KZ1100-L1 (LTD Shaft) (1983)
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 (LTD) (1976)
ZN1100-B1 (LTD Shaft) (1984)
ZN1100-B2 (LTD Shaft) (1985)
Good Fortune! :)
  • baldy110
  • baldy110's Avatar
24 Jan 2013 21:44
#569056
Thanks Patton that is the info I need, 20mm x 1.5mm.
