kz750 no spark?
10 Jan 2013 15:04 #566710 by kwnics
kz750 no spark? was created by kwnics
I replaced bad ignition coil but now I have no spark. Everything is testing fine except one side of dyna s ignition is low ohms. Any help would be much appreciated. Thank you in advance.
10 Jan 2013 16:36 #566724 by Patton
Replied by Patton on topic kz750 no spark?
kwnics wrote: I replaced bad ignition coil but now I have no spark. Everything is testing fine except one side of dyna s ignition is low ohms. Any help would be much appreciated. Thank you in advance.
:unsure: Is there full battery voltage at each ignition coil primary terminal?
Good Fortune! :)
10 Jan 2013 16:39 #566725 by kwnics
Replied by kwnics on topic kz750 no spark?
I believe so...is there a way to test?
10 Jan 2013 16:47 #566727 by Patton
Good Fortune! :)
10 Jan 2013 16:57 #566728 by kwnics
Do I have to have charged battery? And will this test work with multimeter
10 Jan 2013 18:18 #566736 by kwnics
Okay I have 12v going to coils now only 1 and 4 are sparking?
10 Jan 2013 19:38 #566747 by Patton
kwnics wrote: Okay I have 12v going to coils now only 1 and 4 are sparking?
Does this mean that the two outside spark plugs #1 and #4 are sparking (with their plug wires connected to the same ignition coil), and that the two inside spark plugs #2 and #3 are not sparking (with their plug wires connected to the other ignition coil)?
What ignition coils are fitted (stock; Dyna; other)?
What spark plug wires are fitted (stock; Dyna; other)?
To aid diagnosis, could swap wires from Dyna-S between ignition coils to see whether only 2 and 3 are then sparking.
If not already done, could re-test for spark, using new spark plugs, or swap the spark plugs around to see whether it makes any difference as to which plugs spark.
Good Fortune! :)
11 Jan 2013 02:00 #566806 by kwnics
Stock ignition coils with dyna s ignition pickups. Yes 1&4 are running to one coil and 2&3 are running to the other coil. I will run the switching wires test tomorrow.
There is 4 brand new spark plugs and the wires are testing good.
11 Jan 2013 13:17 #566852 by kwnics
Okay ran test with switching wires between dyna s and had spark on the other two with no spark on original so does that mean its the ignition pickup? Thank for all the help!!
11 Jan 2013 13:24 #566853 by loudhvx
Replied by loudhvx on topic kz750 no spark?
Did the bike originally have points? If not, then you may eventually burn out the Dyna S when using stock coils. Dynatek says 3.0 ohms is the minimum resistance for coils used with the Dyna S.
11 Jan 2013 13:28 #566854 by kwnics
The dyna was on there when I bought it. My coils read around 3 ohms resistance. Will bike still run with only 2 plugs sparking. And can I run both coils off one wire from dyna or will that mess things up?
11 Jan 2013 13:58 - 11 Jan 2013 14:04 #566861 by Patton
kwnics wrote: The dyna was on there when I bought it. My coils read around 3 ohms resistance. Will bike still run with only 2 plugs sparking. And can I run both coils off one wire from dyna or will that mess things up?
Will bike still run with only 2 plugs sparking -- Yes, usually, but not very well, and probably barely good enough to out-run an older Harley.
can I run both coils off one wire from dyna -- No
or will that mess things up? -- Yes
Each ignition coil has its own independent "secondary loop" including the secondary winding, both plug wires, plug cap on each plug, the spark plugs themselves, and the metal engine head.
Lost conductivity in the secondary loop disallows spark on both plugs within the loop.
For example, a faulty connection between a plug wire and cap could cause a "break" in the secondary loop.
Has the non-firing secondary loop been ohm-tested between the caps to determine whether there is a "break" within the loop?
Good Fortune! :)
Last edit: 11 Jan 2013 14:04 by Patton.
