removing stator cover
- ramtough_63
09 Jan 2013 23:27
I have never had my stator cover off its time to get busy polishing what all is involved other than removing screws to removing stator cover? 78 KZ1000
It was warm enough could put a few miles on her today if she was ridable so I need to go ahead and get busy while I can 2 more day of being mobile for at least 2 weeks
going in for hopefully the last surgery tomorrow
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- KZJOE900
- Admin
Re: removing stator cover
09 Jan 2013 23:40
1. Take off left foot rest.
2. Unbolt shifter bolt (all the way) and pull shifter off.
3. Remove four bolts and remove chain cover.
4. Bend tabs back holding stator wires in order to gain slack in the wire.
5. Remove screws from stator cover.
6. Remove stator cover but be aware of the wire attached. Have a box or something to rest it on.
If it doesn't want to budge give a few whacks with a rubber mallet. Not hard enough to cause
damage though.
7. Remove there allen bolts holding the windings in the stator cover. Bolts may be held in there with
blue thread lock. So once you break that seal they come out easy.
8. Remove windings with fingers underneath the windings and place on box or whatever you are using to
support it so you don't have to unplug it. When taking the windings out you will have to pull at
rubber grommet the wires go through as you gain slack from the windings. Good luck.
damage though.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- ramtough_63
09 Jan 2013 23:42
Thanks gonna give it a shot thanks
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
The following user(s) said Thank You: KZJOE900
- zukdave
09 Jan 2013 23:43
Should be just like my little motor right.
Three screws and unplug the one connector
under the side cover.
Now getting the sater screws out can
be a real B%%ch but if your careful you could do it
with the wires hanging out.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
09 Jan 2013 23:45
Good luck tomorrow! Ed
- MFolks
10 Jan 2013 00:07
Tilt the bike to the right if possible, to minimize the oil loss, & put down old newspapers or kitty liter to absorb any dropped oil. Don't forget to buy a new gasket for the cover, as the old one will probably tear and leak if re-used.
