model years and interchangeable parts
- ads990
08 Jan 2013 19:13
I have what i think is a 1976 KZ400s. the engine number is k4se014034. My first question is am i correct in guessing its a 400 special? My next question is because parts are so hard to find, are the 76 engines the same as the 77? I have low compression and the dark line of deposits around the head gasket but cant seem to find a gasket set for the 76. Any help is greatly appreciated. The only head gasket for a 76 i found kawi wants 150 for and I find that a little high considering the 77 and 77 full kits are only 50.
Re: model years and interchangeable parts
08 Jan 2013 19:30
You might find this link helpful:
www.kz400.com/ModelidentificationFrameset.html
Look at pictures under “(K)Z400/400 Specs.” If you click on the 1976 S2 picture it shows your engine serial number is in the correct range for the 1976 Special. The Special can be easily identified by the front drum brake; the regular model had a front disk. Ed
08 Jan 2013 19:43
Kawasaki.com currently shows several earlier and later KZ400 models using the same head gasket. Keep in mind, Kawasaki.com does sometimes have errors, so you may want to check other sources before buying. The site I gave a link to in my previous posting would probably be an excellent source. Ed
Attachment 00000_2013-01-08-3.jpg not found
- loudhvx
08 Jan 2013 19:53
The 400's had a bunch of mix-and-match models. Some of the 77 400's were similar to the 76 models, but most were changed to use different carbs, charging systems etc.
If your bike has drums front and back, a 2-into-1 exhaust, no electric starter, no tachometer, then it is the S2 model, I believe. It should have the earlier CV carbs that use pistons instead of diaphragms. You can tell the difference since the piston cv carbs will have large cofee-mug shaped covers on the tops, the diaphragm cv carbs will have a smaller, pie-plate shaped cover on top.
If your motor is not actually leaking, I wouldn't mess with it. Just clean it. Head gaskets are indeed getting hard to come by on those motors, and once they come apart, they seldom go back together as well as the factory did it, especially without factory gaskets etc.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- ads990
08 Jan 2013 21:24
WOW, you guys are fast. Thank you for the info.The dealer near me ordered a few gaskets and ill compare once they come in, I did a leak test earlier and sprayed soapy water around the gaskets and the majority of the front leaked.while doing the teardown i noticed the L exhaust valve was also not sealing right. 650ed- the site you recommended was awsome. Thank you again guys youve been really helpful
