Piston options for an 83 kz750?
  • bobski911
  • bobski911's Avatar Topic Author
07 Jan 2013 22:13
#566279
Hey guys, its time to do some work on the bike now that the snow is here. I'm wanting to put a new primary chain in my 83 kz750f. I'm tired of the rattle. However, I was wondering if there were any option for going up a size in pistons. I know wiseco has pistons but dont want to spend $600+. Would anyone have advice on this?
Thanks
  • wireman
  • wireman's Avatar
Re: Piston options for an 83 kz750?
07 Jan 2013 22:20
#566281
Look for a used block/810 kit on flee bay B)
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
08 Jan 2013 04:15
#566337
There's no cheap way of doing it, but the 810cc Wiseco kit is the one to go for.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • turboguzzi
  • turboguzzi's Avatar
08 Jan 2013 05:12
#566339
been there when i built my racer....
well, all you have to google is "69mm piston, 15mm pin", no?
so you'll find some cheap monkey bike kits that are 69/15, trouble is that they all have the wrong piston crown height and by quite a few mm.
went with wiseco at the end.
  • Motor Head
  • Motor Head's Avatar
08 Jan 2013 10:13 - 08 Jan 2013 10:19
#566350
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration810 kit, bore job, valve job, primary chain, gaskets, oils seals, etc will be more like $1K.
But you should have quite a good result from the upgrade, and rebuild.
Last edit: 08 Jan 2013 10:19 by Motor Head.
  • steell
  • steell's Avatar
08 Jan 2013 12:37
#566355
If you're anywhere near New Jersey, then this is an option (copied from another board, not mine)
1984 KAWASAKI GPZ ZX750 NINJA Parts Bike
I am selling one 1984 Kawasaki GPz ZX750 Ninja “Parts Bike”. I have no title for this bike just a bill of sale. The engine has great compression and would be great for any project you have. The bike comes with the following:
Frame in good shape with no cracks
Engine and trans
Front forks
Rear shock and swing arm
Front and rear brakes system in good condition.
Clean Fuel Tank
Asking $250 or Best Offer. I would like it to good to someone who can use the parts.
My email address is [email protected]
Just posted yesterday.
